Is there any difference between the head of a 3A-U and a 3A-LU?
The toyota codes index says the L stands for transverse mounted engine.
I need to bolt a 3A-U head onto one thats currently got a 3A-LU
fangsport wrote:as far as i'm aware there shouldn't be an issue.
although,a 3A-U engine won't bolt into a transverse bay due to the front (behind timing cover) engine mount bosses not being drilled and tapped .
