3A-U and 3A-LU...differences?
Postby NZcelica » Mon Jun 20, 2005 12:04 pm
Is there any difference between the head of a 3A-U and a 3A-LU?
The toyota codes index says the L stands for transverse mounted engine.
I need to bolt a 3A-U head onto one thats currently got a 3A-LU
ST165 Celica GT-4 <SOLD>
97 GT-T 18psi <GONE>
96 Carib BZ 5 speed
Looking to import a car? PM me
Lots of performance Toyotas forsale. PM me for details
NZcelica
Postby fangsport » Mon Jun 20, 2005 4:53 pm
as far as i'm aware there shouldn't be an issue.
although,a 3A-U engine won't bolt into a transverse bay due to the front (behind timing cover) engine mount bosses not being drilled and tapped .
fangsport
Postby mr pad » Mon Jun 20, 2005 5:37 pm
Be careful once you get it running man. Those 3a's tend to get away on you when your not concentrating. Mad Powa.
mr pad
Postby NZcelica » Mon Jun 20, 2005 6:06 pm
fangsport wrote:as far as i'm aware there shouldn't be an issue.
Cheers.
Yes shes a bit of a power packet, especially when its in an AT150 corona!
Family sedan with a fukn tercel engine!....oh wait....AND ITS AUTO!
96 Carib BZ 5 speed
NZcelica
Postby Adamal » Mon Jun 20, 2005 6:18 pm
3A-U is the Rangi version.... AU!
Postby AJz » Mon Jun 20, 2005 6:30 pm
Adamal wrote:3A-U is the Rangi version.... AU!
hahhaha, nice
I had vtax :(
AJz
Postby Dangerous_Driver » Mon Jun 20, 2005 8:54 pm
l is an outdated motor code for front wheel drive,
if youre putting a rear wheel 3a into a front wheel drive i think the water exits are different and water pump.
My sister can do a better standy!!!
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1365
Dangerous_Driver
Postby kingcorolla » Mon Jun 20, 2005 11:08 pm
can you ask your mate if he has a 3a-u top alternater bracket!?
1983 Carina AA63 4age
kingcorolla
Postby KinLoud » Tue Jun 21, 2005 6:25 am
3a-lu makes a better anchor than the 3a-u.
Based on personal experience.
I have a spare one if you want it - a bit smokey but runs fine.
Ken
Ham
021 408 863
