over boost problem
over boost problem
Postby The Wombat » Mon Jul 18, 2005 7:32 pm
ok hes whats happening.
my rover is over boosting the car should be running on its factory 6-8psi but its going up to 15psi in 1st>3rd gear and the boost cut is coming in, this is when the car is being driven hard. this has only just started to happen shortly after i installed my BOV ( a GFB Basic) at first i thought that the bov was not opening or was staying open, put simply i though is was not working correctly. However i put my mates BOV on my car ( a GFB Bovus maximus) and again it was opening correctly like the previous one and in 1st>3rd gear it was over boosting with ver little power and the boost cut kicked in. there is no boost tap or controller in the car and other than the boost gauge and BOV there is no other work been done to the car around the turbo system.
any thoughts cause this is worrying me. the cars not a daily driver and only gos out 2-3 days most
Current Rides: manual supercharged AW11, 1993 ford fiestiva *BOTH FOR SALE PM FOR DETAILS*
Previous Rides
1995 Rover 220 GTI
1989 Fiat Tipo 1400
1986 AW11 MR2 "written off 7/5/05"
1983 Toyota Levin AE86 20v,1990 Tureno GT APEX, R31 GTR skyline, VK holden, EA Falcon, 2x1980 Mazda 626
The Wombat
Postby CozmoNz » Mon Jul 18, 2005 8:07 pm
Vac / Boost leak.
Rayne For President!
CozmoNz
Postby Pelo » Mon Jul 18, 2005 8:21 pm
Check your wastegate hose, maybe it just started leaking at the same time as your BOV got put on... freeboosting is fun for about 2 minutes....
Pelo
Postby RBRCHKN » Mon Jul 18, 2005 8:34 pm
was there a factory BOV? was it plumback? not sure if that would have much to do with it. bloody hondas :P
Adamal wrote:Then her hands started going to my funny places........
RBRCHKN
Postby The Wombat » Mon Jul 18, 2005 8:49 pm
no factory BOV and i just replace the vacum line (theres only 1 vac line an this car)
Previous Rides
1995 Rover 220 GTI
1989 Fiat Tipo 1400
The Wombat
Postby Fandango » Mon Jul 18, 2005 9:23 pm
Check your wastegate actuator. Sounds like its not opening the wastegate. Try and wiggle the actuator shaft in and out with some pliers.
And of course, check the plumbing to the actuator.
Fandango
Postby evil_si » Tue Jul 19, 2005 6:37 pm
you say there is only 1 vacuum hose?
if that is feeding both the actuator and bov,if so i would change that,
you also say that you changed the vacuum hose, is it a tight fit on to the fittings?
i prefer to drill and tap into the inlet manifold and run seperate fittings and hoses for each,
and you could try putting the actautor hose in at the compressor discharge, rather than off the inlet manifold,
evil_si
Users browsing this forum: Bing [Bot] and 16 guests
