ok hes whats happening.
my rover is over boosting the car should be running on its factory 6-8psi but its going up to 15psi in 1st>3rd gear and the boost cut is coming in, this is when the car is being driven hard. this has only just started to happen shortly after i installed my BOV ( a GFB Basic) at first i thought that the bov was not opening or was staying open, put simply i though is was not working correctly. However i put my mates BOV on my car ( a GFB Bovus maximus) and again it was opening correctly like the previous one and in 1st>3rd gear it was over boosting with ver little power and the boost cut kicked in. there is no boost tap or controller in the car and other than the boost gauge and BOV there is no other work been done to the car around the turbo system.
any thoughts cause this is worrying me. the cars not a daily driver and only gos out 2-3 days most
