3sgte smoke on boost
Postby jimmynz » Wed Jul 20, 2005 6:10 pm
hey guys... wondering if i could have some opinions...
when my st185 comes on boost it leaves behind smoke, i have thought of a few possibilities of causes but what are your thoughts?
any help much appreciated :)
jimmynz
Postby vvega » Wed Jul 20, 2005 6:19 pm
white turbos rooted ... blue engine and turbos rooted :D
v
vvega
Postby JT » Wed Jul 20, 2005 6:24 pm
Black .... its running rich
JT
Postby jimmynz » Wed Jul 20, 2005 6:26 pm
shit you guys are quick ... holding out for white or black!! think it might be blue tho... but i suspected this already.
cheeeeeeeeeeeeeeeeers!
jimmynz
Postby GT-T » Wed Jul 20, 2005 6:52 pm
what does it mean if my car have black smoke when it's on idle when the engine temp. on normal running temp?
For the 3SGTE, what we can do to adjust the fuel mixture? Is the aftermarket ECU and AFC the only two things to do?
I think my car is running quite rich and the fuel eco is not that great....
Help! Please
1999 Caldina GT-T
2000 Merc A160
1998 Integra Type R
http://toyspeed.blakjak.net/profiles/profile.php?id=581
GT-T
Postby Crucible » Wed Jul 20, 2005 7:05 pm
FIRST QUESTION, (Grey SMOKE) If its blowing grey smoke its burning oil either Rings, Valve guides of turbo seals, Take the ducts off the turbo if its oily inside the seals are worn..... if its dry the engine is gettin tired.
QUESTION 2, (Black Smoke) Blocked Airfilter, Faulty Temp sender (Could be signalling ECU thats it cold ie More Fuel), Or High Fuel rail pressure ie faulty Press Reg or restricted return Line, Injectors could need flushing also
Hope this helps some...just my 2 cents :lol:
Crucible
Real Life Mechanic
Postby jimmynz » Wed Jul 20, 2005 8:08 pm
True-No-Turbo wrote:FIRST QUESTION, (Grey SMOKE) If its blowing grey smoke its burning oil either Rings, Valve guides of turbo seals, Take the ducts off the turbo if its oily inside the seals are worn..... if its dry the engine is gettin tired.
thanks man will have a look :)
jimmynz
Postby vvega » Wed Jul 20, 2005 8:12 pm
sorry but grey/white smoke is not rings
turbo's do not have valve seals
also if its exhaust stem seals the turbo wiill still be wet
i cant be bother pickkiing more
v
vvega
Postby Crucible » Wed Jul 20, 2005 9:35 pm
v[/quote]
I Disagree, Grey smoke is oil control problem, Oil bypassing Control rings will burn in the combustion chamber and produce Grey/white smoke, Im not saying it "IS" Oil control rings Im suggesting it "May" be!!. Just as a matter of interest....What colour smoke are you saying oil burning would produce? I realise Turbos dont have valve seals?, never said they did? Geez even my dog knows that!... but they have seals that prevent oil entering the housings...This would cause Grey Smoke if they were worn on either side!!...I agree with the comment on valve stem seals but minor weapage would be burnt off in the manifold....The seals and Guides also would have to be Very badly worn to reach the turbo to see any signs of oil and It would be burning Very bad smoke if it was, Which I dont think it is!!?. Im definatly no Turbo expert by a long shot!!... but taking off a Duct on the intake side and seeing oil inside the pipe would suggest the seals are weaping...Its alot quicker than unbolting exhaust flanges and trying to have a look...
Just my opinion.....Could be wrong! :lol:
Crucible
Real Life Mechanic
Postby EVLGTZ » Wed Jul 20, 2005 9:59 pm
True-No-Turbo wrote: Valve guides of turbo seals
True-No-Turbo wrote:I realise Turbos dont have valve seals?, never said they did? Geez even my dog knows that!
ya sure?
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby Crucible » Wed Jul 20, 2005 10:12 pm
Oops...Ive been sprung.... :cry:
Let me refrase that.....Valve guides "OR" Turbo seals
My apologies.....I eat my words...HeHe :lol:
Crucible
Real Life Mechanic
Postby vvega » Thu Jul 21, 2005 7:36 am
ok to help you understand
and smoke produced during the combustion cycle is blue
why because its burnt more effentiatlty though the compression ignition cycle
any smoke burn after that is white
why ... tri dropping some oil on a hot plate and you will see
that also means that if your turbo leaks on the compressor side that the smoke will be blue
bad compression rings will mist out the rocker cover
this is attually the oil been burnt off the bore walls buy the heat and pflame bypassing the rings
the only thing i see you have correct is the "i am no ...expert"
and as for your dog
well they say that dogs are like there owners and he was wrong as well
were not all 16yr old that have look up shit on the internet
some of attually know what where talking about
you would be wise to listen
v
vvega
Postby Fandango » Thu Jul 21, 2005 12:04 pm
and as for your dog
were not all 16yr old that have look up sh*t on the internet
v
GOOD point. :D
Fandango
Postby Crucible » Thu Jul 21, 2005 2:23 pm
Ok Ok.....You are correct, you obviously do know what you are talking about and are obviously a clever guy as per your trade...I apologise for that, yep it is more Blue than grey in colour!!...Ive jumped the gun!!
I Dont want to cause a fire....Just trying to help a guy out with a problem as I am a Qualified Mechanic with 20 yrs in the Trade....but hey I work with another four tradesman and we question each others diagnostics every day and if we are unsure on something thats not our cup of tea its outwork....
I always end my posts with "Just my 2 cents" or "I could be wrong" because I dont know everything and will be still learning to my grave thats why I joined this group!...maybe you can help me on a few things!?
Anyways I think this may be a bit off topic and I think our man has enough info to go on so cheers
b.t.w I think you offended my Dog cause he stopped humping my leg! :lol:
Crucible
Real Life Mechanic
Postby vvega » Thu Jul 21, 2005 6:17 pm
lol
im sure if you think about it .it all makes sence
:D
ps im sure your not that upset abotu your dog not humping your leg
v
vvega
Postby Dutch » Thu Jul 21, 2005 11:21 pm
'if its dry the engine is gettin tired'
Errr, what does this actually mean. I have seen this phrase mentioned many times, and it still doesn't make an ounce of sense to me :?:
Dutch
Postby Akane » Fri Jul 22, 2005 10:15 am
Another mechanic who fix up cars for a living but don't really know their crap.
It's guys like these who $&#$% up cars like mine. Thanks.
Yes, I'm still sour about it, and not getting over it.
Postby Crucible » Fri Jul 22, 2005 9:05 pm
Akane wrote:Another mechanic who fix up cars for a living but don't really know their crap.
Hmmmm.......
I Came out with top Student in the first year of my Pre - Trade out of 22 Students, I was an M.T.A Apprentice. I have National Cert, Trade Cert and Advance trade Certificates in Automotive Engineering, I am also an AVI Authorised Inspector and been In the trade for 18 - 20 years, with experiance on cars from V8s to BMWs. I am a Contract Mechanic and work for myself and rely on my Knowledge and skills of the Trade to Earn a living......I take pride in my work and I have never had a job come back on me ever thats caused conflict and Loss of a Customer....So I think I can say with confidence I know my crap and I DONT F**K up cars!!!
VVega didnt explain until his second post what he was suggesting about worn rings...also I thought he didnt read my post properly and was acusing me of saying something I didnt, so Naturally I Saw Red and replyed without really thinking...Sorry again V! :lol:
So next time your at the lights picking your nose and a car in front of you is burning oil...you have a look at that haze and pinpoint with confidence wheater its either Blue or Grey Smoke......I Bet with confidence yah cant!!!
NUFF SAID!
Crucible
Real Life Mechanic
Postby Akane » Fri Jul 22, 2005 9:59 pm
Yeah alright, you're pro.... :roll:
You surely do know your crap. Tell me where your shop is I'll take my car to you to "fix up" next time. Coz you sound like the next Lynn Rodgers.
Postby CozmoNz » Fri Jul 22, 2005 10:08 pm
True-No-Turbo wrote:So next time your at the lights picking your nose and a car in front of you is burning oil...you have a look at that haze and pinpoint with confidence wheater its either Blue or Grey Smoke......I Bet with confidence yah cant!!!
at a guess...... id say its burning oil, but your the pro ;)
seriously man, whatever you do, dont come along here and act cocky, im not trying to be insulting... but its pretty open on here, and seriously, you dont know how much these chaps do or dont know...
Rayne For President!
CozmoNz
