when my st185 comes on boost it leaves behind smoke, i have thought of a few possibilities of causes but what are your thoughts?
any help much appreciated
True-No-Turbo wrote:FIRST QUESTION, (Grey SMOKE) If its blowing grey smoke its burning oil either Rings, Valve guides of turbo seals, Take the ducts off the turbo if its oily inside the seals are worn..... if its dry the engine is gettin tired.
QUESTION 2, (Black Smoke) Blocked Airfilter, Faulty Temp sender (Could be signalling ECU thats it cold ie More Fuel), Or High Fuel rail pressure ie faulty Press Reg or restricted return Line, Injectors could need flushing also
Hope this helps some...just my 2 cents
True-No-Turbo wrote: Valve guides of turbo seals
True-No-Turbo wrote:I realise Turbos dont have valve seals?, never said they did? Geez even my dog knows that!
the only thing i see you have correct is the "i am no ...expert"
and as for your dog
well they say that dogs are like there owners and he was wrong as well
were not all 16yr old that have look up sh*t on the internet
some of attually know what where talking about
you would be wise to listen
v
Akane wrote:Another mechanic who fix up cars for a living but don't really know their crap.
It's guys like these who $&#$% up cars like mine. Thanks.
Yes, I'm still sour about it, and not getting over it.
True-No-Turbo wrote:So next time your at the lights picking your nose and a car in front of you is burning oil...you have a look at that haze and pinpoint with confidence wheater its either Blue or Grey Smoke......I Bet with confidence yah cant!!!
