3SGTE, ecu question
3SGTE, ecu question
Postby crispy'86 » Tue Aug 02, 2005 8:58 pm
Got a mate who's going to be running an ST165 celica gt4 engine in his viva race car, he's wanting an ecu and un-cut loom for one. The question is does it need to be the exact ecu and loom to drive the engine?? I want to back up my theory that it has to be the same ecu from engine, i know they are all AFM but would it make a difference running an ST185 gt4 loom and ecu or an SW20 one??
crispy'86
Postby Akane » Tue Aug 02, 2005 11:55 pm
Yes you'll need the exact same loom, bigger injectors in ST185/SW20.
different spark setup too IIRC.
Postby RunningRich » Wed Aug 03, 2005 1:16 pm
Akane wrote:Yes you'll need the exact same loom, bigger injectors in ST185/SW20.
That's rubbish, the injectors are closes enough (440cc/430cc).
Compression is different between the ST165 and St185. Other than that not much difference in parameters. Turbo/head differs of course.
Some rewiring of loom may be required if ST185 loom is used, but he would be removing a lot of the unecessary items anyway right?
Richard
http://gtfour.supras.org.nz
RunningRich
Postby crispy'86 » Wed Aug 03, 2005 6:36 pm
I figured that's what the case would be, few people have said this. Well thanks for that info, much appreciated.
crispy'86
Postby Akane » Wed Aug 03, 2005 8:29 pm
Just because you like to do things the rubbish way, that don't mean my proper way of doing things is rubbish.
Think before you post.
