Primo wrote:Thanks for ur replys
and i figure out that 4efte bolts on straigt into a car where as 4age needs no move the engine foward a bit in the drivers side rite?
Primo wrote:I rekon black top 20v is faster than 4efte, i might be wrong i havn drivn 4efte b4 so.,.....
Primo wrote:N if i put 4age engine + suspension + box then i can get away with cert?
Primo wrote:it was from 1.3L 12v to 1.6L 20v???? so wouldn it be quite a lot of difference? Also putting Brake and fuel pump... can i get away with it?
Primo wrote:hmm another thing... how much are the 4age 20v black top or 4efte and how much cert cost???
Primo wrote:The guy in my work said one of his mate can do it for 350~450....hmmm
Thanks again for ur replys and.. i just need bit more helpthnks
Primo wrote:I asked the guy again and he was talking about 16v not 20v and he said it will bolt staight on
Primo wrote:I have a quesition that wheater 20v and 16v CV is in same plac
Primo wrote:and also im putting gearbox with it so i dunno.,.
Primo wrote:Another question if i get gearbox n engine out from starlet gt would gearbox will fit easily??
Primo wrote:And gruntposter i red the post how the guy juiced out 145hp out from ee90 does any one know how to make that happen what to put in????
Primo wrote:so is the 4efte gearbox doesn bolt on rite?
QikStarlie wrote:you can use the standard box with the 4e, but wont last if your a rapsit
