AJz wrote:really, i didnt know caldinas had such a thing.....![]()
110V wont power your power supply, NZ is 240V member, unless its a US laptop.
AJz wrote:you would wanna check the laptop first tho.
TWSTD wrote:AJz wrote:you would wanna check the laptop first tho.
Its the powersupply that you would need to check, not the laptop - and yes mine is 110-230v as are many (most?) laptop power supplies
fivebob wrote:You will probably find that the output is square wave or modified sine wave, and your power supply may not work as the voltage peaks may be lower than it requires.
All_Fours wrote:fivebob wrote:You will probably find that the output is square wave or modified sine wave, and your power supply may not work as the voltage peaks may be lower than it requires.
I agree that it probably runs a modified sine wave, as a pure sine wave inverter is pretty expensive, but a simple power supply for a laptop, which just rectifies back to DC, shouldn't have any problems with it provided the output from the inverter is a true 110VRMS.
Infact when you think about it, it seems kind of silly going from DC (car supply) -> AC -> DC to charge your laptop, you could easily build a voltage regulator circuit (or buy a pre-made one) provided the required voltage for charging the laptop is less than about 13VDC, and it will be more efficient than running through 2 wave converters.
I guess that doesn't answer the question of whether the outlet works though...
Santa'sBoostinSleigh wrote:i cant say ive check the 110V plug, but my 12V rear plug goes.
however the button must be pushed in and the car must be in the 'on' position (eg it dont go in the 'acc' position on the ignition)
/me adds "shove multimeter into 110V socket on the caldina" to the TO DO: list
XERO wrote:I need some thing to check it with... i know if i hit that switch, it lights up...
TWSTD wrote:Santa'sBoostinSleigh wrote:2 bits of wire and ya tounge
PLEASE PLEASE PLEASE Please dont get drunk and do that Mark....
Santa'sBoostinSleigh wrote:TWSTD wrote:Santa'sBoostinSleigh wrote:2 bits of wire and ya tounge
