question - is it worth extending the box right up to the throttle body to prevent the heat getting to the rest of the pipe? at the moment the bit of pipe in the air box remains cold but the bit outside it gets reasonably warm
gepsk8 wrote:if ur using aluimin to pipe will heat up. that's y ppl you stainless steel not affected by heat so much.
say it was turbo you would use aluimin pipe from turbo to the intercooler(cause the intercooler will cool down the air) stainless out of the intercooler to intake manifold.(cause its not so affected by heat!)
