Cold air box question
Postby gordon77 » Sun Oct 23, 2005 10:26 pm
i have recently made a cold air box and installed a pod filter. the box goes around the filter and up the pipe a little bit (200mm)
question - is it worth extending the box right up to the throttle body to prevent the heat getting to the rest of the pipe? at the moment the bit of pipe in the air box remains cold but the bit outside it gets reasonably warm :?
What is RR?
gordon77
Postby vvega » Sun Oct 23, 2005 10:56 pm
i doubt you would notice any differance
you have got the cold air going into the tube and that is the aim for what you have done
v
vvega
Postby gordon77 » Mon Oct 24, 2005 10:07 am
sweet thats what i wanted to hear :) thanks man
What is RR?
gordon77
Postby gepsk8 » Mon Oct 24, 2005 4:02 pm
if ur using aluimin to pipe will heat up. that's y ppl you stainless steel not affected by heat so much.
say it was turbo you would use aluimin pipe from turbo to the intercooler(cause the intercooler will cool down the air) stainless out of the intercooler to intake manifold.(cause its not so affected by heat!)
gepsk8
Postby evil_si » Mon Oct 24, 2005 4:12 pm
gepsk8 wrote:if ur using aluimin to pipe will heat up. that's y ppl you stainless steel not affected by heat so much.
stainless holds heat a lot longer, alloy cools a lot faster.
most people only go for stainless as its shiny to start with
evil_si
Postby Skidman » Mon Oct 24, 2005 7:05 pm
If your worried about heat getting in just wrap the pipe in that thermal shit that keeps stuff cold, (bit bogie but just cut up some of those cool chain bags they keep the heat out) :P
Hondas are made for people who dont know better.
Skidman
