rallymazda wrote:the problem is some wreakers say I need to buy the driveshafts out of a 6 speed levin as they are different to the 5 speed ones, while other wreakers say they are the same
sergei wrote:I don't understand why you need new drive shafts, even if it is LSD box, it is Helical LSD, C160 will work fine with C5X shafts, as I am using C52 driveshafts in my C160 box...
levin_it_large wrote:Just can't quite understand why you would pay $1,000 + for another gear and slightly closer ratios. O well
how many AE101 you see with 6 speed in them?)
levin_it_large wrote:how many AE101 you see with 6 speed in them?)
Not many if any... because no AE101 drivers would add one to their car... being 1/2 the value of the car
BZG Wagon wrote:levin_it_large wrote:how many AE101 you see with 6 speed in them?)
Ever heard of a BZ Touring Corolla?
AE101 4AGE, 6 Speed Gear Box - Standard. There are quite a few around.
bad20v wrote:Thought so.... and didn't they come out in about 1995 when the first ae111 coupes started being produced but the ae101 wagons were still in production with blacktop engines?
