6speed box install
6speed box install
Postby rallymazda » Tue Nov 01, 2005 5:17 pm
I currently have a 95 levin with a 5 speed box but I want to upgrade to a 6 speed box
the problem is some wreakers say I need to buy the driveshafts out of a 6 speed levin as they are different to the 5 speed ones, while other wreakers say they are the same
has anyone done this swap before?? or know whether I need to change the drive shafts
[4AGE8U] << my old number plate
Got me a new altezza, now arrived
1991 corolla wagon- work hack
rallymazda
Postby Adydas » Tue Nov 01, 2005 5:50 pm
why not ask the wrecker to get a shaft from each car.. and see what sizes they are??
Adydas
Postby phatman3801 » Tue Nov 01, 2005 6:32 pm
the wreaker might just say he needs new ones so he can sell them as well tho :P
current project/ride: BZG levin
phatman3801
Re: 6speed box install
Postby barryogen » Wed Nov 02, 2005 7:52 am
rallymazda wrote:the problem is some wreakers say I need to buy the driveshafts out of a 6 speed levin as they are different to the 5 speed ones, while other wreakers say they are the same
Get the GB. make sure you know a wrecker that has a DS(and you have the cash to get it), make a weekend of it, and borrow someone elses car incase you need to go get the DS.
Oh yeah, and document what you do so that others may profit from your (mis?)fortune of being the first.
barryogen
2ZZ Guru in training
Postby sergei » Wed Nov 02, 2005 8:19 am
I don't understand why you need new drive shafts, even if it is LSD box, it is Helical LSD, C160 will work fine with C5X shafts, as I am using C52 driveshafts in my C160 box...
Postby bad20v » Wed Nov 02, 2005 10:35 am
sergei wrote:I don't understand why you need new drive shafts, even if it is LSD box, it is Helical LSD, C160 will work fine with C5X shafts, as I am using C52 driveshafts in my C160 box...
Everything seems to be the same in my BZR too. Maybe the wrecker just trying to rip you off. :?
Thank-You.
bad20v
Postby levin_it_large » Wed Nov 02, 2005 3:41 pm
Just can't quite understand why you would pay $1,000 + for another gear and slightly closer ratios. O well
levin_it_large
Postby barryogen » Wed Nov 02, 2005 3:44 pm
levin_it_large wrote:Just can't quite understand why you would pay $1,000 + for another gear and slightly closer ratios. O well
Bling factor?
The ability to say "I have one more than you"?
The "My gearbox is bigger than yours" syndrome?
The "because I can"?
I could go on, but I wont, bacause I have work to do, but you get the idea.
barryogen
Postby sergei » Wed Nov 02, 2005 9:43 pm
well, the reason why I did it is because I blew up my C52 in first place, so I've decided to go for something different (how many AE101 you see with 6 speed in them?)
Postby levin_it_large » Wed Nov 02, 2005 10:54 pm
Not many if any... because no AE101 drivers would add one to their car... being 1/2 the value of the car :roll:
levin_it_large
Postby sergei » Thu Nov 03, 2005 8:12 am
well now there is atleast 1 :D , btw you will have problems with shifter, as 5 speed shifter does not have enough left to right movement, cheapest way is to go to pick a part and pull an AE101 20v shifter out as they are made out metal and can be modified (file it little bit to get it go properly in reverse), as far as I know AE111 are plastic and complete pain in the butt to modify, althou you might run in some other problems (the way wich cables are connected to plastic is different from metal)
Postby rallymazda » Thu Nov 03, 2005 5:03 pm
thanks for the replys guys
i think ill chance it and buy the box without the drive shafts and she if they fit
and as for the $1000? im paying $600, hopefully nothings wrong with it
and i have already brought a trd short shifter for a 6 speed so there shouldnt be any problems there...... fingers crossed
ill let you know how it goes
rallymazda
Postby gepsk8 » Thu Nov 03, 2005 6:56 pm
just letting u know da top mount on the gear box doesn't line up i've been told.
needs to be moved.
gepsk8
Postby sergei » Thu Nov 03, 2005 10:32 pm
not moved, mutilated... actually not mount but mount plate, need to bend/redrill some bits to fit... also if you are going to use 6 speed shifter, you will need 6 speed cables, they are different (atleast on 5 speed AE101)
Postby BZG Wagon » Mon Nov 07, 2005 2:58 pm
Ever heard of a BZ Touring Corolla?
AE101 4AGE, 6 Speed Gear Box - Standard. There are quite a few around.
BZG Wagon
Postby bad20v » Mon Nov 07, 2005 5:04 pm
Don't they have a blacktop engine though? :?
Thank-You.
bad20v
Postby Alex B » Mon Nov 07, 2005 5:41 pm
Yes they are still ae101 tho.
Postby bad20v » Mon Nov 07, 2005 5:45 pm
Thought so.... and didn't they come out in about 1995 when the first ae111 coupes started being produced but the ae101 wagons were still in production with blacktop engines?
Thank-You.
bad20v
Postby matt dunn » Mon Nov 07, 2005 10:07 pm
bad20v wrote:Thought so.... and didn't they come out in about 1995 when the first ae111 coupes started being produced but the ae101 wagons were still in production with blacktop engines?
Yup.
You can get a 1996 on 6 speed BZT corolla wagon with a blacktop
in either AE101 or AE111. They were both in production at the same time.
Postby Mr Revhead » Mon Nov 07, 2005 10:12 pm
yep ae101 production in the wagons ended in 1999
Users browsing this forum: Majestic-12 [Bot] and 26 guests
