1998 wrote:Powa bar is far superiour to a impact wrench.
Just use the biggest socket set you have (you'd want bigger than half inch atleast) and the biggest f*ckoff bar you can find. Heaps of CRC as Silent Knight says.
rollas22 wrote:1998 wrote:Powa bar is far superiour to a impact wrench.
Yep used the perfect sized socket, with a large f#*K off power bar, heaps of CRC and still wont budge at all!!! Gunna give the crank over wit starter motor a blast tonite.
rollas22 wrote:TrouserFxGt wrote:ccw thread?
WOuldnt have a clue bud. How do u tell???
rollas22 wrote:Yep ive removed the radiator, and have tried using the powerbar with the extension and the socket! but no success. Must have some extreme locktite on it or something. Think the rattle gun is the only option that will work.
RomanV wrote:rollas22 wrote:Yep ive removed the radiator, and have tried using the powerbar with the extension and the socket! but no success. Must have some extreme locktite on it or something. Think the rattle gun is the only option that will work.
Are sure you're turning it the correct way?
SIDE_FX wrote:put your wrench watever on the bolt and tap it wit a metal headed hammer sounds daft but after this old guy watched me trying to do the same to my 4age crank came a did it took him 4 hitsi felt so stupid
Skidman wrote: but then again nothing dose..dose it?
