ae85 20v 4age conversion- wiring!!! yay!
Postby wannabe86 » Sun Dec 04, 2005 9:31 am
there are 4 wires going from engine thru firewall.
colours are:
black/orange (goes to same colour wire in ae85 on ignition?)
black/white (goes to same colour wire in ae85 on ignition?)
can anyone tell me what the two white wire are for? one is thicker than the other.
does anyone have a 20v ae85 in auckland area that i could have a look at?
wiring diagrams don't show this as far as i have seen. thanks
jon
wannabe86
Postby Rick » Sun Dec 04, 2005 10:43 am
Are you talking about the wires on the drivers side where they come through the firewall?
Postby wannabe86 » Sun Dec 04, 2005 1:37 pm
yes. there is that large black plug. on ae85 and ae86, there are more wires but no white ones.
wannabe86
Postby crispy'86 » Sun Dec 04, 2005 7:13 pm
have you got it sorted?? If not the black/orange wire is for ignition feed when key is on, black/white starter feed, as most toyotas are. White should be permanent power, either for alternator aswell as ignition feed to switch
crispy'86
Postby suckymotor » Tue Dec 06, 2005 9:30 am
hows the conversion going would be keen for a look at some stage to see what it looks like copaired to my one
suckymotor
TS Original Member
Postby wannabe86 » Tue Dec 06, 2005 6:54 pm
thanks crispy. that is helpful
suckymotor: sure you can. i would be keen to see yours too. :)
give me a call sometime. 021355868.
wannabe86
