MA61 motor swap: 5M only running on 3cyl
Postby ps165 » Thu Jan 19, 2006 10:44 pm
ive just finished swaping the motor in MA61, its a straight motor replacement, so was nice and easy :) ..i do have 1 problem though, the motor will only run on 3 cylinders (rear 3)
plugs and leads are all ok. and all lead are getting spark. fuel pump was fine before we took the old motor out (a week ago) anyone have any ideas....?? cheers
ps165
Postby Malcolm » Thu Jan 19, 2006 10:49 pm
blocked fuel rail or injectors? Remove the whole rail with injectors still in, crank motor and see if they all spray :D
Postby ps165 » Thu Jan 19, 2006 10:53 pm
replacement motor went fine in last car, but hadnt run in 2-3 months.
All_Fours wrote:blocked fuel rail or injectors? Remove the whole rail with injectors still in, crank motor and see if they all spray :D
yeh thats a good idea. does it come straight out, or do i need to remove other thing to get to it?
ps165
Postby Malcolm » Thu Jan 19, 2006 11:03 pm
I helped a friend with an engine conversion and the motor ran perfectly well in the old car, then in the new one it was only running on 3 cylinders (3sgte). Turned out to be a blocked injector.
The fact that one end of the motor isn't running is why I think it could be a blocked fuel rail. Could also be insufficient fuel pressure.
Anyway I don't know how the fuel rail comes out on a 5M, should be fairly easy though
Re: MA61 motor swap: 5M only running on 3cyl
Postby Toymad » Fri Jan 20, 2006 4:44 pm
ps165 wrote:ive just finished swaping the motor in MA61, its a straight motor replacement, so was nice and easy :) ..i do have 1 problem though, the motor will only run on 3 cylinders (rear 3)
The 5M runs a resistor pack for the injectors and it is an aluminium block with a three wire connector. It mounts on the inner guard and connects to the engine loom in the area of the distributor. It houses two resistors for two banks of three injectors:
http://www.cygnusx1.net/supra/library/T ... E_004.html
It could be a simple connection problem. If not, check the resistance for each resistor - one may have blown......
David
Toymad
Postby ps165 » Fri Jan 20, 2006 6:05 pm
David
thanks heaps for that info, i used the loom off the transplant engine and dont remember connecting up the part you refer too, so that could well be the problem :) i will post on my progress, cheers
ps165
Postby deaf_rattle » Fri Jan 20, 2006 10:04 pm
did you put in a cressida 5mge? there are a few differences with those 5mges
Postby ps165 » Sat Jan 21, 2006 5:57 pm
deaf_rattle wrote:did you put in a cressida 5mge? there are a few differences with those 5mges
not went from 1 celica xx to another :)
ps165
Postby ps165 » Mon Jan 23, 2006 1:49 am
thanks for all the suggestions, and big thanks to Toymad!!! it indeed was exactly what you described, the problem lay in the plactic connectors, one of the spade terminals had been pulled halfway out resulting in there being no caontact between the 2 wires ;) very simple to fix. now i can get it out of the workshop and finnaly get some pics.
ps165
