plugs and leads are all ok. and all lead are getting spark. fuel pump was fine before we took the old motor out (a week ago) anyone have any ideas....?? cheers
All_Fours wrote:blocked fuel rail or injectors? Remove the whole rail with injectors still in, crank motor and see if they all spray
ps165 wrote:ive just finished swaping the motor in MA61, its a straight motor replacement, so was nice and easy..i do have 1 problem though, the motor will only run on 3 cylinders (rear 3)
Toymad wrote:ps165 wrote:ive just finished swaping the motor in MA61, its a straight motor replacement, so was nice and easy..i do have 1 problem though, the motor will only run on 3 cylinders (rear 3)
The 5M runs a resistor pack for the injectors and it is an aluminium block with a three wire connector. It mounts on the inner guard and connects to the engine loom in the area of the distributor. It houses two resistors for two banks of three injectors:
http://www.cygnusx1.net/supra/library/T ... E_004.html
It could be a simple connection problem. If not, check the resistance for each resistor - one may have blown......
David
