bluemaumau wrote: handbrake will need to be replaced all the way to the actual handbrake as it is one cable
check to see if some over anxious mechanic tried the torquetillsnapsthenbackitoff trick. have seen plenty lately where the male fitting has flared inside the female fitting, making it very hard to undo, and near on impossible to re-fit.MrOizo wrote:well that was ass!
really the only thing holding me back was the size of the hose line. so back to drums :/
physically and theoretically they should be the same. was right length and all that but didnt wanna screw into place. (its the hose end that mates up with the hard line from the chassis)...![]()
might have another go another day but losing motivation for doing this fast
One thing that looked to be of concern also was the rear suspension arm - looked as if the bush was a little too wide to fit in it... hmmmm
another pinch-a-part mission might be needed
