brake lines
brake lines
Postby bluemaumau » Tue Feb 21, 2006 5:32 pm
ok ive got my donor levin (gt-apex) and im about to put the 4 wheel disk brakes (hubs) onto the wagon
the wagon has 2 front disks and drumies on the back.
obviously both the drummies and disks have fluid lines.
but my question is.....
should i replace the lines with gt-apex items or a the wagons lines identical?
cheers in advance
Postby MrOizo » Tue Feb 21, 2006 5:38 pm
Kinda need to know the same thing..
swapping from AE91 drums to AE92 FXGT Disks
viewtopic.php?t=43336
are you going to swap proportioning valve and all that?
is it even necessary? :)
MrOizo
Toyspeed Legend
Postby bluemaumau » Tue Feb 21, 2006 5:50 pm
yea the valve is a necessity i think. im doin ae101
Postby bluemaumau » Tue Feb 21, 2006 10:08 pm
thanks for every1s help
:roll:
Postby 20v_rollaboy » Tue Feb 21, 2006 10:49 pm
do you mean the complete line that runs from the engine bay to the rear wheels?
if so, no need to. they are the same. i had a look when i got my brakes off the trueno.
if i have time tomorrow ill take my wheel off and get a pic for you if you want, as i used to have drummies on the back aswell
20v_rollaboy
Postby bluemaumau » Wed Feb 22, 2006 12:40 pm
cheers man. that would be wicked. :D
Postby 20v_rollaboy » Wed Feb 22, 2006 11:15 pm
Heres a pic of my rear discs, converted from drummies.
And heres the bottom subframe, which I took the chance to paint while I had the car in pieces.
20v_rollaboy
Postby MrOizo » Wed Mar 29, 2006 10:34 pm
hey hey,,,
kinda a random bump but i am hoping to be doing this, this weekend.
just some questions:
which hoses did you use and what does the proportioning valve look like exactly? its it basically a T-Joint?
cheers!
MrOizo
Toyspeed Legend
Postby 20v_rollaboy » Wed Mar 29, 2006 10:53 pm
Used the Trueno`s brake lines, and the proportioning valve is in the engine bay, mounted on the firewall near the middle I think. Should have one line coming from the resovoir (sp) and four going to each hub.
Hope this helps :)
20v_rollaboy
Postby MrOizo » Wed Mar 29, 2006 11:11 pm
cheers for that...
will have a look tomorrow and sort something ou t:D
gotta to go to pinch a part first :D
MrOizo
Toyspeed Legend
Postby bluemaumau » Wed Mar 29, 2006 11:39 pm
ive done it once,
20v rollaboy done it twice!
haha yea just do what he said 8)
Postby MrOizo » Thu Mar 30, 2006 8:45 am
oh another thing...
handbrake cables?
use the setup from the donor car and all is good?
MrOizo
Toyspeed Legend
Postby bluemaumau » Thu Mar 30, 2006 8:59 am
what cars?
yes you need the handbrake cable.
my gt-apex cable fitted the wagon perfectly 8O :?
20v rollaboy tells me that you will need the valve, as he had a incident the other night
Postby MrOizo » Thu Mar 30, 2006 9:38 am
oh damn shit! 8O
i have the whole hub assembly incl brake hoses and handbrake cables too.
car its going in/on to is a AE91 sedan.
car its come from is a AE92 FXGT
hope its all good~! :D
MrOizo
Toyspeed Legend
Postby bluemaumau » Thu Mar 30, 2006 4:05 pm
should be swwet,
just replace the valve with the fx item
replace the hubs.
join the sedans brake lines to the fx's just were they enter the guard.
handbrake will need to be replaced all the way to the actual handbrake as it is one cable 8)
Postby MrOizo » Thu Mar 30, 2006 4:08 pm
bluemaumau wrote: handbrake will need to be replaced all the way to the actual handbrake as it is one cable 8)
oh shit... naa there should be a swivel in the middle right?
i have 2 hubs in the boot and each one have cables...
will find out over the weekend anywyas,.,
thanks for your help so far :D
MrOizo
Toyspeed Legend
Postby bluemaumau » Thu Mar 30, 2006 5:00 pm
oh nah sorry there is a swivel.
im not sure if ur sedan one will mate up with the fx item tho. i just used all the levins parts 8)
Postby MrOizo » Mon Apr 03, 2006 10:19 pm
well that was ass!
really the only thing holding me back was the size of the hose line. so back to drums :/
physically and theoretically they should be the same. was right length and all that but didnt wanna screw into place. (its the hose end that mates up with the hard line from the chassis)... :?
might have another go another day but losing motivation for doing this fast :P
One thing that looked to be of concern also was the rear suspension arm - looked as if the bush was a little too wide to fit in it... hmmmm
another pinch-a-part mission might be needed :o
MrOizo
Toyspeed Legend
Postby bluemaumau » Mon Apr 03, 2006 10:32 pm
yea join it at the hard line. mine fit easy. :P
Postby fangsport » Mon Apr 03, 2006 11:41 pm
MrOizo wrote:well that was ass!
check to see if some over anxious mechanic tried the torquetillsnapsthenbackitoff trick. have seen plenty lately where the male fitting has flared inside the female fitting, making it very hard to undo, and near on impossible to re-fit.
fangsport
