silvertop computer help
Postby shihad » Thu Mar 23, 2006 3:51 pm
I have an AE92 trueno with a manual silvertop in it.I found out recently from the guy who put the engine in that its running an auto computer.Would this be the cause of lack of power that my car puts out? Is it worth putting a manual computer in? Any help would be great
shihad
Postby johntramp » Thu Mar 23, 2006 4:01 pm
apparently you loose about 10%
johntramp
Postby sergei » Thu Mar 23, 2006 5:16 pm
There is no difference in power from manual to auto ECU! even redline is the same.
Postby slighty_looney » Thu Mar 23, 2006 5:34 pm
actually i heard u get more low end out of the auto computer man, id stick with it aye
FC3S
Robinson Steel Fabrications
Current Ride: 88 rx7
Project: viewtopic.php?t=88412
Discussion: viewtopic.php?t=88413
slighty_looney
Postby johntramp » Thu Mar 23, 2006 9:39 pm
well what I had heard was that the auto ECUs have a more conservative fuel map so that it is not be as stressful on the gearbox... but then again I dont know if there is any truth there.
johntramp
Postby deaf_rattle » Thu Mar 23, 2006 11:19 pm
johntramp wrote:well what I had heard was that the auto ECUs have a more conservative fuel map so that it is not be as stressful on the gearbox... but then again I dont know if there is any truth there.
my ae92 with silvertop goes pretty well, i doubt there would be any change with a manual ecu
Postby Ae92typeX » Fri Mar 24, 2006 1:08 am
actually, I heard if you put a trd sticker on them they gain 20kw...or wait, did I hear thet was hearsay...
shihad, have you dyno'd your car, or are you just assuming it is down on power?- could be worth checking things like timing etc etc
Ae92typeX
Postby deaf_rattle » Fri Mar 24, 2006 7:22 am
Ae92typeX wrote:actually, I heard if you put a trd sticker on them they gain 20kw...or wait, did I hear thet was hearsay...
yeah, straight after the conversion, i noticed the rear wheels would break traction, and i could drift corners.
i installed a boost gauge and im running 10pounds.
it also beats rs legacies
Postby bluemaumau » Fri Mar 24, 2006 1:39 pm
surely theres a diff in power outputs between manual and auto,
why else would car companys quote stuff like this when selling:
2001 sti wrx manual -220hp
2001 sti wrx auto -210hp
(not actual figures)
i see that all the time
and surely its because of the ecu, its not like the compression or pistons are different :?
or maybe the silvertops just a retard :wink:
Postby sergei » Fri Mar 24, 2006 2:36 pm
Does not actually applies to silvertops etc. (as being relative low power/ low torque engine in first place).
Postby shihad » Fri Mar 24, 2006 5:40 pm
i have had the timing checked its definately losing power somewhere.the temperature gauge never worked properly since the conversion so my mate has a theory that the ecu temp sensor is screwed or something.
shihad
Postby CozmoNz » Fri Mar 24, 2006 6:01 pm
rs leggys arnt fast.....
not stock they arnt anyway.
Rayne For President!
CozmoNz
Postby sergei » Fri Mar 24, 2006 6:05 pm
The temperature guage is separate from water tempereature sensor.
What gas are you running? On 20v 91 is nono, and 95 is marginal.
How is your fuel economy?
What colour are the sparkplug tips?
What timing advance is it running?
What sort of power loss are we talking about?
Postby deaf_rattle » Fri Mar 24, 2006 6:24 pm
bluemaumau wrote:surely theres a diff in power outputs between manual and auto,
i wouldve thought drivetrain loss, but those figures are at the fly... who knows.
i know the old vr4 autos had smaller turbos or something, so mayber there is something to this...
