johntramp wrote:well what I had heard was that the auto ECUs have a more conservative fuel map so that it is not be as stressful on the gearbox... but then again I dont know if there is any truth there.
Ae92typeX wrote:actually, I heard if you put a trd sticker on them they gain 20kw...or wait, did I hear thet was hearsay...
shihad, have you dyno'd your car, or are you just assuming it is down on power?- could be worth checking things like timing etc etc
deaf_rattle wrote:Ae92typeX wrote:actually, I heard if you put a trd sticker on them they gain 20kw...or wait, did I hear thet was hearsay...
yeah, straight after the conversion, i noticed the rear wheels would break traction, and i could drift corners.
i installed a boost gauge and im running 10pounds.
it also beats rs legacies
bluemaumau wrote:surely theres a diff in power outputs between manual and auto,
why else would car companys quote stuff like this when selling:
2001 sti wrx manual -220hp
2001 sti wrx auto -210hp
(not actual figures)
i see that all the time
and surely its because of the ecu, its not like the compression or pistons are different
