NO2
NO2
Postby [A NINJA] » Thu Mar 30, 2006 7:31 pm
questions concerning nitros'n my black top 4A-GE
the kit will be a 50hp-75hp kit
What will I need to do? ie pistons, zoorst, ECU etc???
many thanks
if cost over 3k, I wont do it and I will buy another car!
www.tusken-raiders.tk
NINJA!!!!!!!!
[A NINJA]
Postby TrouserFxGt » Thu Mar 30, 2006 7:42 pm
If your motor is healthy I would recomend retarding your timing to 8 degrees and possibly change your fuel filter if you haven't done it.
cue misinfo and neysayers now.
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
Postby sergei » Thu Mar 30, 2006 8:01 pm
it is N2O.
Postby Dell'Orto » Thu Mar 30, 2006 8:02 pm
Definately free up the exhaust. 50 -75hp kit will be fine on stock ECU/pistons. Provided you dont balls up the mixture :lol:
Postby Caveman » Thu Mar 30, 2006 8:15 pm
Use a wet system, harder to balls up.
ZEX system might be around the $1000 mark?
Then setup the system to a WOT switch, ie nos turns on at full throttle 8)
Caveman
Postby Al » Thu Mar 30, 2006 8:34 pm
Are you going to run 4 individual jets?
Al
Postby bluemaumau » Thu Mar 30, 2006 9:07 pm
cert maybe need -400 dollars ->goodbye
Postby Go_the_mini » Thu Mar 30, 2006 9:19 pm
certs are only $340 now arnt they?
Go_the_mini
Postby [A NINJA] » Thu Mar 30, 2006 9:24 pm
I have been looking at ZEX's website.... I will probly use a wet kit of their's! Wow I dont think you are allowed to use N02 kit on the street?! I thought if you got caught with blue flames out the zoorst it was big fine time! I will be using this kit for draging at the track
NINJA!!!!!!!!
[A NINJA]
Postby Al » Thu Mar 30, 2006 9:43 pm
Its good to see someone willing to give nitrous a go, it will more than likely eat your clutch if its a stocker.
Can't really beat it for hp/dollar 8)
Al
Postby Dell'Orto » Thu Mar 30, 2006 9:44 pm
I dont think you need to have nitrous certified, it doesnt increase power 20% (permanently ;) )
Postby [A NINJA] » Thu Mar 30, 2006 10:11 pm
http://www.powerandperformancenews.com/ ... Code=82021
is what Im looking at....
I tell you what... getting the NO2 kick in 3rd would be a big difference down the track!
NINJA!!!!!!!!
[A NINJA]
Postby Al » Thu Mar 30, 2006 10:12 pm
Why wait till 3rd :?
Get some street legal hoosiers and use it from the launch 8)
Al
Postby bluemaumau » Thu Mar 30, 2006 10:54 pm
Go_the_mini wrote:certs are only $340 now arnt they?
i dont actually know, it was just a guess,
hopefully cuz the gze will need one 8)
Postby touge rolla » Fri Mar 31, 2006 12:34 am
nos is completely legal without cert, just a bit too vin diesel for my liking though :lol: (sorry)
touge rolla
Postby bluemaumau » Fri Mar 31, 2006 12:39 am
touge rolla wrote:nos is completely legal without cert
didnt know that
$&#$% this country has some $&#$% up cert rules :evil:
Postby Caveman » Fri Mar 31, 2006 2:48 am
http://www.lvvta.org.nz/Engine&Drive-trainConversions09.pdf
Look under section 2.3(3)
Everything you need to know about low volume vehicle certificates is on http://www.lvvta.org.nz/
Caveman
Postby adamkerrnz » Fri Mar 31, 2006 9:46 am
i read a while back that you need to install a blowback system (when excessive pressure within the bottle is released to prevent any accidents)
2003 Toyota Echo 1.3
adamkerrnz
Postby tomo1985 » Fri Mar 31, 2006 9:59 am
I went down this track last year. You wanna run a wet system as this will stop leaning out and detonation.
You wanna run four jets so each cylinder gets the same amount on gas. Upgrade your fuel system.
Retard timing.
2 3 degree colder sparkpulgs.
Wide Open Throttle switch.
Bigger exhaust
New Clutch
RPM Switch (This makes it so N2O can be armed and wont come on till a set rpm causing less stress on your engine)
I did a lot of research and found that its not a great idea in a black top as people overseas had tried it with many rods breaking and engine failure.
But hey if you have the money to do it go for it. I didnt so sold it.
tomo1985
Postby Malcolm » Fri Mar 31, 2006 12:36 pm
FFS IT'S N2O, NOT NO2! although who knows? maybe you can pioneer nitrogren dioxide injection?
