by tomo1985 » Fri Mar 31, 2006 9:59 am
I went down this track last year. You wanna run a wet system as this will stop leaning out and detonation.
You wanna run four jets so each cylinder gets the same amount on gas. Upgrade your fuel system.
Retard timing.
2 3 degree colder sparkpulgs.
Wide Open Throttle switch.
Bigger exhaust
New Clutch
RPM Switch (This makes it so N2O can be armed and wont come on till a set rpm causing less stress on your engine)
I did a lot of research and found that its not a great idea in a black top as people overseas had tried it with many rods breaking and engine failure.
But hey if you have the money to do it go for it. I didnt so sold it.
tomo1985 on Fri Mar 31, 2006 5:23 pm, edited 1 time in total.
