by KinLoud » Sun Apr 23, 2006 6:45 pm
W55 - 3.58 1st gear
Often W55's are found behind 4 cylinder engines - lower 1st gear helps when you have a bit less torque I guess (ask mr toyota).
W57 - 3.28 1st gear over all slightly closer gearing 1st, 2nd, 3rd... 4th and 5th same as W55
W58 - same as W57 except that 5th is 0.78 to keep the revs lower when cruising.
What are your revs at 100kph in 5th?
What does the build plate codes say?
Ken
Ham
021 408 863
