3t = 1g gte help please
Postby L0w_st4rlet » Tue Apr 25, 2006 6:59 pm
change of plans just got car out of inpound and am proceding with the plans of engine conversion. I am ditching the 3tgte and have aquired a full reg and warrented mkIII supra adj boost rebuilt turbos 3" exhaust manual and am going to put the engine and gearbox into my car. Planning on using supra fuel system in my coronas fuel tank. will this work? also for mounts I was just going to grind my X-member smooth and cut complete mounts off supra X-member and get engineer to weld them on to my corona X-member when its all dummied up in the car and also get him to make up gearbox X-member. will i need to shorten driveshaft going from t50 to W series? what will be needed in wiring as most will be just a transfer from car to car correct? What size intercooler will be best with single turbo in mind? I have been told the corona diffs are quite heavy and i presume it will handle ther power already has a LSD in it. How are the turbos cooled would I use supra oil cooler if they are oil cooled or go with an aftermarket option? what boost can these handle would it pay to get a link or microtech or just a piggyback ecu? any suggestions welcome please no hipocrits just looking for help in the conversion also anyone running one of these engines what are some mods that bring positive returns. cheers
L0w_st4rlet
Postby Quint » Tue Apr 25, 2006 10:32 pm
You'd get more answers if you thought out ur post better, but that aside.
I'd worry about the prop shaft having a differant spline on the output shaft rather than the length. (can't recal which ones are interchangable).
As for boost i personally wouldn't run anything over 12, without considering changeing to GZE pistons.
Ahh. Yes, they have an oil cooler. (i believe). Just get a decent plumbing system on it and she should go nicely for you. Oh, and your turbos will pop at 12psi, they are $&#$% useless. Replace with a single CT-20.
Quint
i
Postby L0w_st4rlet » Tue Apr 25, 2006 10:58 pm
i can use spline off supra driveshaft and put it on my driveshaft.
how much would I be looking at or the ct 20 and how much modification is needed to get it fitted
L0w_st4rlet
Postby mad_te71 » Wed Apr 26, 2006 1:28 am
whats the chasie model of your corona? because i dont think the diff will handle it unless its a F series.
[User is Suspended. Offensive Sig Removed]
mad_te71
i
Postby L0w_st4rlet » Wed Apr 26, 2006 11:51 am
what turbo is better as u said the ct20 but i seen a supra on trademe with basic mods with a ct26 making 284kw or something like that.
L0w_st4rlet
i
Postby L0w_st4rlet » Wed Apr 26, 2006 12:02 pm
what turbo is better as u said the ct20 but i seen a supra on trademe with basic mods with a ct26 making 284kw or something like that. and i dnt no the chassis code its the sort of long sedan with the pointed bonnet will post a picture it has been lowered more since pic and has mirror tints
http://i64.photobucket.com/albums/h195/ ... ona001.jpg
L0w_st4rlet
Postby mad_te71 » Wed Apr 26, 2006 5:49 pm
get a ga61 1983 supra G series crosssmember and it will bolt into your car and engine and box should bolt straight in.
mad_te71
i
Postby L0w_st4rlet » Thu Apr 27, 2006 12:18 am
will that crossmember go straight in or will an engineer need to fit it. will the W series box fit straight in ie:
driveshaft spline from t series fit the w series?
gearbox crossmember?
or will I have to get an engineer to fabricate custom ones?
any help appreciated keep it coming guys heaps of help.....
L0w_st4rlet
Postby mad_te71 » Thu Apr 27, 2006 11:07 pm
alright the ga61 xmember will bolt inthen engine will bolt in too gearbox xmember should bolt up too or if it doesnt get 1 from a w series gearbox of a ta63 celica or ga61 supra , use the supra driveshaft aswell only if you have 2 piece driveshaft will this work.
mad_te71
i
Postby L0w_st4rlet » Fri Apr 28, 2006 10:29 am
sweet as do you know where i can pick one of those crossmembers from
L0w_st4rlet
Postby mad_te71 » Fri Apr 28, 2006 11:33 pm
yea only in christchurch
mad_te71
