by Quint » Tue Apr 25, 2006 10:32 pm
You'd get more answers if you thought out ur post better, but that aside.
I'd worry about the prop shaft having a differant spline on the output shaft rather than the length. (can't recal which ones are interchangable).
As for boost i personally wouldn't run anything over 12, without considering changeing to GZE pistons.
Ahh. Yes, they have an oil cooler. (i believe). Just get a decent plumbing system on it and she should go nicely for you. Oh, and your turbos will pop at 12psi, they are $$% useless. Replace with a single CT-20.
