ae111 6 speed box on a silver top
Postby levinguy » Wed Apr 26, 2006 7:48 pm
are the ae111 6 speed boxes bolt on to ae101 levins?
what do i need to change for a 6 speed box?
levinguy
Postby sergei » Wed Apr 26, 2006 8:05 pm
Left engine mount plate needs to be butchered, also you will need to modify gear shifter, to allow more left movement to be able to shift it into reverse. Other than that it is a "straight bolt on".
Postby levinguy » Wed Apr 26, 2006 8:11 pm
what exactly would i have to do the engine mount plate?
and how would i modify the shifter? jus cut into it?
would it be easier to get one from a ae111?
levinguy
Postby 4000GT » Wed Apr 26, 2006 8:29 pm
Hopefully I will be doing ths, well helping doing this, this weekend... I have the shifter though.
Supra MKIV Aerotop (UZA80FTE conversion) STATUS: 3 months to go!
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
Free online business and reporting tools visit www.e-solver.com
4000GT
Postby sergei » Wed Apr 26, 2006 9:09 pm
just having shifter will not help, if you are going to use AE111 shifter you will need the cables as well. Or you can modify (file litle bit so it will allow more movement). with gearbox mount plate from AE101 I had to flatten it out and drill holes in it so will be possible to use AE101 mount. The AE111 mount is completly different.
Postby sergei » Wed Apr 26, 2006 9:10 pm
make sure you get BZR gearbox, other wise this excersize is just waste of time and money.
Postby 4000GT » Wed Apr 26, 2006 9:17 pm
sergei wrote:just having shifter will not help, if you are going to use AE111 shifter you will need the cables as well. Or you can modify (file litle bit so it will allow more movement). with gearbox mount plate from AE101 I had to flatten it out and drill holes in it so will be possible to use AE101 mount. The AE111 mount is completly different.
I have the cables... the sifter includes both of them :)
4000GT
Postby levinguy » Wed Apr 26, 2006 9:42 pm
iv found myself a box :D
seeing as you've done it, should i get a 6 speed shifter or modify mine?
thats all i need is it?
levinguy
Postby sergei » Wed Apr 26, 2006 9:58 pm
you can modify it, saving some $$$... I also modified, but I used handle from BZR as it allows some shorter shift. Just remove center console which covers the shifter have play with it and you will figure out what needs to be filed to get more movement.
Postby levinguy » Wed Apr 26, 2006 10:01 pm
and what exactly did you have to do to the engine mount? was it a squeeze?
levinguy
Postby sergei » Wed Apr 26, 2006 10:05 pm
the gearbox is pretty much same size, the diffrence is the mounting of the engine mount plate (well the BZR does not have one) I had to redrill holes in that plate to use 6speed mounting points. Also I made it so it was holding on 4 bolts instead originally 3, I used one of the shifter bolts as plate bolt.
Postby levinguy » Wed Apr 26, 2006 10:40 pm
argh decisions decisions!
6 speed box verus suspension verus exhaust verus mags : :twisted: :twisted:
levinguy
Postby sergei » Wed Apr 26, 2006 10:42 pm
dont bother with 6 speed, get LSD, or better E58 (or whatever the code)+ shafts off AE101 GTZ...
Postby levinguy » Wed Apr 26, 2006 10:43 pm
this 6 speed has a lsd
levinguy
Postby sergei » Wed Apr 26, 2006 10:45 pm
My priority would be (if I were you):
Suspension
G-box
Mags
Lots of other mods.
more mods.
Exhaust.
Exhaust is silly mod, it only creates porblems with cops/neighbours etc. but on bog standard car has very minimal effect of increase of power (if at all).
Postby gasman » Wed Apr 26, 2006 11:47 pm
theres a 6 speed box on tm at the moment and im just wondering whats involved in getting one of them to fit a black top thats in a ae92 and is $800 sounding like a fair price just for the box?
"What can possibly go wrong?"
gasman
Postby bluemaumau » Wed Apr 26, 2006 11:49 pm
800?!
you can get e58s for like 300-400
whats so great about 6 gears anyway, just another gear change...
Postby gasman » Wed Apr 26, 2006 11:57 pm
bluemaumau wrote:800?!
but if i get the e58 i will need new shafts wont i?
gasman
Postby sergei » Wed Apr 26, 2006 11:59 pm
the only down side of E58 is that gearing is a bit long...
Postby bluemaumau » Wed Apr 26, 2006 11:59 pm
i dont actually know, im going to find outin a few days when i start to complete my conversion, ask me then :P
