Custom Forged Piston manufacturers.
Postby RedMist » Tue May 23, 2006 11:01 pm
Need to select a good priced piston manufacturer for my new traitorous V6 project.
I want to build the first v6 cheaply and use it as a testbed. Upon proof of concept I'll develop a second much higher spec engine. Unfortunately the current pistons have little dome and I need to bump compression in the range of 13:1 as I'll be running silly duration.
Any suggestions would be appreciated. So far I have tried.
In CHCH, we have
Denco- which apparently are heavy.
Proturn- that doesnt appear to have a race history.
States
Crower, good pistons, but will be about 2.4k for a full set.
Arias, good pistons, slightly cheaper
Wiseco
Ausi
ACL, have heard good things about their bearings, but bad things about their cast pistons, hopefully their forged product is better.
anywhere in Ausi or NZ I should consider?
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Grrrrrrr! » Tue May 23, 2006 11:12 pm
ACL can do custom forgies
http://www.aclperformance.com.au/prod_p_forged.htm
No idea on quality or price on custom forged pistons, but there stock 20v low compression forged pistons are around $800+gst from memory.
Grrrrrrr!
Postby RedMist » Wed May 24, 2006 8:32 am
Good price.
Have sent them an email, hopefully they can replicate a similarly good price for my custom v6 forged pistons.
RedMist
Postby crnkin » Wed May 24, 2006 11:41 am
Me being me I always reccomend arias, The run $675 usd for a full set of custom pistons for 4 cylinder, and you know theyre gonna last. Just an option anyways!
deaf_homo "currrently yes"
crnkin
Postby Fortyone.co.nz » Wed May 24, 2006 12:06 pm
Cosworth?
Fortyone.co.nz - For Bride, EBC, KTS, JUN, Tomei, HKS, Trust, Blitz and more!
Fortyone.co.nz
Postby RedMist » Wed May 24, 2006 1:34 pm
crnkin wrote:Me being me I always reccomend arias, The run $675 usd for a full set of custom pistons for 4 cylinder, and you know theyre gonna last. Just an option anyways!
I run Arias in my 4age. And those things have taken serious abuse. I'll see what they can do for me.
RedMist
Postby matt dunn » Wed May 24, 2006 7:22 pm
we run Denco ones in our 1GGTE engine in our old celica and wqe found them good. Can't comment on nthe weight of them as it was a while ago.
(They would still be in there if one of the guys who was co-driving at an enduro diddn't hook 2nd instead of 4th)
If the first engine is an experimental version they may be worth another look.
Matt
Postby atmosports » Wed May 24, 2006 9:07 pm
CP Pistons, we run them in all sorts of things & have never had one fail yet, & they are generally one of the lighter pistons you can buy, we even went to the trouble of designing our own for a project & only ended up 4grams lighter than what CP could offer. Don't buy them locally though, go to OZ & buy them fom Quantum, think their site is www.qri.biz.
I've always found Denco to be pretty heavy & have had some bad experiences with Proturn pistons(I've had good experiences as well though). JE Pistons are nomrally alright providing you get JE's & not SRP pistons. Else yes Arias,Cosworth,Crower but stay away from Wiseco's seen a few too many broken though around the gudgeon bosses.
The ACL forged pistons I looked at in RIPCO looked alright, but felt heavy but I'm yet to weigh one & compare it & my hand scales aren't very accurate.
atmosports
Postby RedMist » Wed May 24, 2006 10:23 pm
These are for my custom racing 6a10 Mitsubishi. I say custom because I want to alter pin height and deck the block to suit. The piston and pin will need to be extrememly light as I currently wish to retain stock rods. In addition because of the extremely small stroke computer modling is pointing towards an extremely heavily cammed engine with a 10k rpm limit. As such every gram will count.
The early gsxr1000, r1 and zX9r and my 6a10 all have the same bore. I was hoping to modify a piston and use a motorcycle rod. However I cant find bugger all information regarding any motorcycle rod. let alone if the big end or length on the above are any where near correct.
RedMist
Postby Bazda » Wed May 24, 2006 11:11 pm
I reccomend JE forged pistons, last time i checked it was around $1300 for 4 pistons landed in NZ. But now the dollar has changed im not sure.
Very good quality and light as well.
Postby atmosports » Fri May 26, 2006 6:15 pm
One manufacturer I forgot to mention was Mahle , we did an evo not long ago & the pistons we're pretty good, coated & all as standard both skirts & crown. Have no idea where to buy them from or any idea on cost.
atmosports
Postby Stu- » Fri May 26, 2006 6:42 pm
Mahle are imported by Ralliart NZ now. You used to have to get them from OZ. They're good pistons.
Project Thread
Stu-
Postby MikeMan » Sat May 27, 2006 2:36 am
Accralite have a good rep in the UK.
MikeMan
Postby pitman » Fri Mar 09, 2007 10:34 am
what are the negatives of having heavy pistons? i ask as i am looking at buying a built 4g63 wich has denco pistons. will be used as a daily street /once a month drag car aiming at around 400whp
ex-toyletgt
ex-license holder.oops
0211845906
pitman
Users browsing this forum: Google [Bot] and 23 guests
