4AGE flywheels and clutches
Postby Stealer Of Souls » Wed May 31, 2006 10:31 am
Hey.
Is there any reason I couldn't use the bluetop clutch and cover on a blacktop flywheel?
I'm guessing the only real issue would be that the flywheel will wear to the smaller clutch. Then when I wanted to use the bigger clutch and cover I'd need to get the flywheel machined, which may result in the flywheel being too thin or something like that...
Is there any other reasons?
Has anyone actually tried to fit a 213 clutch and cover into a K50?
I've read that it doesn't fit, but a quick trial with the broken box I have at home, it looks like it might actually fit...
'86 AE85.5 Levin
Stealer Of Souls
Postby suckymotor » Wed May 31, 2006 10:09 pm
just use a blue top flywheel and clutch
suckymotor
TS Original Member
Postby Jebus » Thu Jun 01, 2006 11:53 am
suckymotor wrote:just use a blue top flywheel and clutch
Im assuming he wants to use the Blacktop flywheel because it is pretty light, and cheaper/safer than machining the blue top one.
Id like to know the same Q too.
Jebus
Postby Stealer Of Souls » Thu Jun 01, 2006 4:12 pm
That's the nail.
Got a blacky sitting in the closet. And am thinking of using it. But at the same time, when I finally get off my A and sort out a T50 I'd wanna use the slightly bigger clutch face. Would seem a little silly to unduly wear the blacky and need to get it machined...
I dunno...
'86 AE85.5 Levin
Stealer Of Souls
Postby CMS » Thu Jun 01, 2006 10:21 pm
I've got a blue top flywheel lyin in the garage if you want one. It doesn't like my GTE. :(
Comber Motor Sport
"If you're not living on the edge, you're takin' up too much space!"
CMS
Postby Stealer Of Souls » Fri Jun 02, 2006 10:09 am
I've already got a bluetop flywheel, cover and clutch on my car.
'86 AE85.5 Levin
Stealer Of Souls
