3SG blocks
3SG blocks
Postby GT4 20 » Sat Jun 24, 2006 7:15 pm
What are the main differences between a Gen II 3SGE block from a Celi and 3SGTE block from a 215 Caldina?
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby strx7 » Sat Jun 24, 2006 10:11 pm
the oiling system is different from what I can tell, the ST215 engine has the filter attached to the upper part of the sump (alloy) it then has a "tin" hat below that. the 2nd gen 3SGE type block has the filter on the side, and has a one piece 'tin' type sump.
Postby Akane » Sun Jun 25, 2006 6:01 pm
Well there's no squirters for starters.
Postby RomanV » Sun Jun 25, 2006 7:09 pm
Yep gen 3 onwards blocks had the oil squirters (both NA and turbo) whereas the gen 2 NA didnt.
The caldina 3SGTE block also has all of the reinforcing mods to prevent blocks cracking etc, which was (sometimes) problem with earlier ones.
Also sump mounted oil filter, as opposed to being on top of the oil cooler.
Caldina block will also have the allowances for the crank angle sensor, which the gen 2 block wont have. (Although the NA and turbo gen 4 blocks have a different crank angle sensor system, IIRC)
Are you considering using a celica gen 2 block?
Perhaps you might want to have a look here
http://www.clubaw.co.nz/forum/viewtopic.php?t=1147
Gen 4 blocks are worth the money IMO, if you're going to make a high revving NA motor.
Someone else wanted the head, so you could probably get just the block if you organised something with him.
I recall an AW11 in the targa a few years ago, running a 3sge. They went through a few blocks in their time, kept on cracking. (as they were using the gen 2 motor, IIRC)
Postby GT4 20 » Sun Jun 25, 2006 10:52 pm
I have a Gen IV head and a Gen II block with the option of a Gen IV block. Just wondering if the Gen IV block option was worth taking up - which it appears that it is.
Thanks for the replies.
Gray
GT4 20
Postby Akane » Tue Jun 27, 2006 10:57 am
Gary if you do wish to sell me the Gen 2 block, let me know.
