deaf_rattle wrote:i dont want excessive "screamer" noise coming from the car, but would like to do something a wee bit different.thanks
deaf_rattle wrote:would like to do something a wee bit different.
True-No-Turbo wrote: have you thought about just plumbing it back into the exhaust??
YeMs wrote:im assuming the same rules will apply as with your exhaust. i think the only reason people get away with having a screamer pipe is they just look like some sort of discreet dump pipe that doesnt leak at idle while they are doing the wof and doesnt grab attention.
YeMs wrote:i guess if u make it look more like a 'mini exhaust' its gunna stand out like dogs balls and they are gunna go "hmm yeh, nah that wont do"..
True-No-Turbo wrote:deaf_rattle wrote:i dont want excessive "screamer" noise coming from the car, but would like to do something a wee bit different.thanks
have you thought about just plumbing it back into the exhaust??, You just need to run it through a flexi so the pipe doesnt crack.
deaf_rattle wrote:will i need a flexi pipe? i thought that was just for fwd and 4wd, because of the way the engine moves.
my exhaust doesnt have a flexi joint in it.
