running exhaust off external wastegate
Postby deaf_rattle » Sun Jul 09, 2006 6:39 pm
would there be any issues in running a seperate exhaust off the external wastegate, and running it through its own muffler and exiting just behind the drivers door?
i dont want excessive "screamer" noise coming from the car, but would like to do something a wee bit different.
thanks
Postby postfach » Sun Jul 09, 2006 6:44 pm
i just checked the LVVTA document regarding exhausts and it doesn't say it cant come out the side, there are rules about heat shielding and stuff tho so maybe worth a look http://www.lvvta.org.nz/Engine&Drive-tr ... ions09.pdf
go to section 2.3(9)
plenty of useful info in this one too, seems to have everything else in there about exhausts too http://www.lvvta.org.nz/Noise%20Emissio ... 030706.pdf
postfach
Postby Loudtoy » Sun Jul 09, 2006 6:49 pm
Think it also has to be behind the mid point of the car as well as 40mm behind the rear most door which ever is furthest back, although in your case it will be 40mm behind the door.
Double check because i remember reading this somewhere but can't find it now that i'm actually looking for it.
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Re: running exhaust off external wastegate
Postby Crucible » Sun Jul 09, 2006 7:01 pm
deaf_rattle wrote:i dont want excessive "screamer" noise coming from the car, but would like to do something a wee bit different.thanks
have you thought about just plumbing it back into the exhaust??, You just need to run it through a flexi so the pipe doesnt crack. :lol:
Crucible
Real Life Mechanic
Postby postfach » Sun Jul 09, 2006 7:11 pm
deaf_rattle wrote:would like to do something a wee bit different.
True-No-Turbo wrote: have you thought about just plumbing it back into the exhaust??
plumbing it back into the exhaust isn't really all that different, hence why he's thinking about giving the wastegate it's own mini exhaust system, of sorts
postfach
Postby YeMs » Sun Jul 09, 2006 8:47 pm
im assuming the same rules will apply as with your exhaust. i think the only reason people get away with having a screamer pipe is they just look like some sort of discreet dump pipe that doesnt leak at idle while they are doing the wof and doesnt grab attention. i guess if u make it look more like a 'mini exhaust' its gunna stand out like dogs balls and they are gunna go "hmm yeh, nah that wont do"..
mind u.. if it was a v8 in an old (insert preferred 50's/60's cruiser here) .. and u swapped the wastegate for side exiting pipes controlled by some dodgy 50's mechanical flap device controlled by a funky retro in-cab cable/lever thingy that couldnt seal the exhaust if its exsitence relied on it then yeh sure, not a problem. iv seen it happen.
Your local Hybrid Elite tech
YeMs
Postby postfach » Sun Jul 09, 2006 8:55 pm
YeMs wrote:im assuming the same rules will apply as with your exhaust. i think the only reason people get away with having a screamer pipe is they just look like some sort of discreet dump pipe that doesnt leak at idle while they are doing the wof and doesnt grab attention.
YeMs wrote:i guess if u make it look more like a 'mini exhaust' its gunna stand out like dogs balls and they are gunna go "hmm yeh, nah that wont do"..
dont those 2 sentences kinda contradict each other? a screamer pipe that exits inside the engine bay is illegal for that very reason, it exits in the engine bay. you are allowed a seperate pipe from the external wastegate as long as it exits within the the exhaust guidelines set out by the LVVTA, which allow rear or side exiting exhausts. if you watched PCTV the other week one of the skylines in the streetcar challenge or whatever had a dump pipe that was short and exited in the engine bay, the cert guy they had on the show said to either plumb it back or extend it to the rear of the car.
postfach
Postby flygt4 » Sun Jul 09, 2006 9:06 pm
wastegate pipes also tend to vent a fair few flames as well when the engine is being abused , probly another reason why its not so good to have them venting inside the engine bay. :?
although thats where mine currently vents to :oops: , id like to have it plumbed into the exhaust but thats a low priority and can be done when i eventually get a whole new system.
flygt4
Postby deaf_rattle » Sun Jul 09, 2006 9:08 pm
will i need a flexi pipe? i thought that was just for fwd and 4wd, because of the way the engine moves.
my exhaust doesnt have a flexi joint in it.
Postby postfach » Sun Jul 09, 2006 9:09 pm
yeah if you're going that route the best time to do it is when you do the rest of the exhaust, a friend of mine had his exhaust done and then failed a WOF because of his dump pipe, had to pay $300 to get it plumbed back, probably would have been cheaper if he'd done it first time round.
postfach
Postby postfach » Sun Jul 09, 2006 9:11 pm
deaf_rattle wrote:will i need a flexi pipe? i thought that was just for fwd and 4wd, because of the way the engine moves.
probably best to ask an exhaust place about that, i have one on my soarer (came on the standard downpipe im using) but the exhaust doesn't seem to move at all so i dont know that it was really needed, i guess better safe than sorry?
postfach
Postby deaf_rattle » Sun Jul 09, 2006 9:13 pm
hmm ok.
the reason im wanting to go seperate pipe is to make the exhaust/manifold easier to remove.
if it was a seperate pipe it could just be unbolted from the waste gate and then removed.
Postby deaf_rattle » Sun Jul 09, 2006 9:14 pm
and my exhaust is already made, 2.5" one lukey muffler and an action dan special.
will have to get the downpipe remade to suit the new turbo.
will the exhaust from the wastegate be quiet enough, if only passing through one muffler?
Postby postfach » Sun Jul 09, 2006 9:16 pm
i assume it will be a small diameter pipe, so it shouldn't be too loud, probably also depends on the length muffler you plan on using
my other post about my mate failing his wof was directed at flygt4, i should have specified sorry matt
postfach
Postby deaf_rattle » Sun Jul 09, 2006 9:18 pm
yeah, will be a smaller diameter pipe, probably 1.5".
will probably be about 1.5m-2m of pipe work.
will have to go to a muffler shop to see what sort of mufflers they can do, but even a mini super turbo style would probably be ok, and then a small tip just infront of the rear wheel, probably not visible unless you know its there kinda thing
Postby postfach » Sun Jul 09, 2006 9:19 pm
sounds like a pretty cool idea, i'd like to see pics of it if/when you get it done
postfach
Postby deaf_rattle » Sun Jul 09, 2006 9:21 pm
will do, will be a few months off tho, paying for my JE pistons this week 8)
Postby postfach » Sun Jul 09, 2006 9:25 pm
heh i know the feeling, theres always something to be paid for, damn projects :P
postfach
Postby deaf_rattle » Sun Jul 09, 2006 9:29 pm
ha yep, will be keen to have a look at your soarer one of these days.
Postby postfach » Sun Jul 09, 2006 9:43 pm
yeah i'll get around to taking some photos and putting them online soon, i'll let you know
postfach
