True-No-Turbo wrote:Im putting bluetops in mine before i chuck it back on the dyno with new link and fuel upgrade, Is it really worth it though?. I mean if its not going to make that much of a differance Id rather spend a bit more money on a decent set.
Would 272 cams be ok for street? I mean would I still have a reasonable idle and be able to achieve a reasonable tune with a link? or would they be a bit too much for street car? Im aiming for 190 ~ 200kw atw!
flygt4 wrote:True-No-Turbo wrote:Well initially a good power band is what Im after but I dont want to affect the driveability too much as is a daily driver,
geez you chose the wrong engine then didnt you
flygt4 wrote: geez you chose the wrong engine then didnt you
RomanV wrote:Generally small displacement, high rpm engines dont have much going on down low. (Even more so when modded)
AE85coupe wrote:hey while on the topic of bluetop cams, do you only need the camshafts themselves and thats all, when you want to put the into a red-top, or do you need buckets/shims etc as well?
