Blue top cams in red top
Postby skiddemon » Sat Jul 15, 2006 12:39 pm
HI, i got word that chucking blue top cams in a non tvis redtop, last generation, is a good idea, cos they got higher duration etc ,Is it?cheers
skiddemon
Postby Pelo » Sat Jul 15, 2006 12:49 pm
Go for it, specs are
Bluetop: 240' duration 7.56mm lift
Redtop-tvis: 232' duration 7.1mm lift
They only changed the cams due to emissions regulations. Cheap mod for small gain.
Someone FAQ this :roll:
Pelo
Postby Mr Revhead » Sat Jul 15, 2006 12:52 pm
not really worth the hassle unless you already have it in bits.
not sure how much difference they make on n/a but have been shown to make a small difference on fi
Postby Crucible » Sat Jul 15, 2006 1:13 pm
Im putting bluetops in mine before i chuck it back on the dyno with new link and fuel upgrade, Is it really worth it though?. I mean if its not going to make that much of a differance Id rather spend a bit more money on a decent set.
Would 272 cams be ok for street? I mean would I still have a reasonable idle and be able to achieve a reasonable tune with a link? or would they be a bit too much for street car? Im aiming for 190 ~ 200kw atw!
Crucible
Real Life Mechanic
Postby crnkin » Sat Jul 15, 2006 1:51 pm
True-No-Turbo wrote:Im putting bluetops in mine before i chuck it back on the dyno with new link and fuel upgrade, Is it really worth it though?. I mean if its not going to make that much of a differance Id rather spend a bit more money on a decent set.
$20 compared to $1000, its not a "bit more".
272's will idle ok for street, but thats not even an issue. The power band, is.
stock cams have been proven to well over your target figure. just look at bazda's car, 330 kw on stockers (blacktop but hey)
To answer the original question. Your butt dyno wont even notice it. Every little bit counts tho
deaf_homo "currrently yes"
crnkin
Postby Crucible » Sun Jul 16, 2006 1:41 pm
Well initially a good power band is what Im after but I dont want to affect the driveability too much as is a daily driver, Anyone know any before and after (KW) figures on what sort of approx gain Id get with 272's??, What would need to be done to head etc to fit them as in regards to springs buckets etc? Are they a suitable cam for a turboed car in the way of overlap etc??
Can anyone shed some light?
thanks
Crucible
Real Life Mechanic
Postby crnkin » Sun Jul 16, 2006 2:14 pm
what lift 272's?
Kind of hard to say a before and after, as a whole lot of other things need to be done first.
There a good choice for turbo car, but maybe not a street turbo car, ive seen 304 8mm lift toda cams in a 4agte, and it cracked 500ps at the wheels, but it had mucho no powero until 6.5k.....
crnkin
Postby Jebus » Sun Jul 16, 2006 8:00 pm
Jebus
Postby flygt4 » Sun Jul 16, 2006 8:18 pm
True-No-Turbo wrote:Well initially a good power band is what Im after but I dont want to affect the driveability too much as is a daily driver,
geez you chose the wrong engine then didnt you :wink:
flygt4
Postby Crucible » Sun Jul 16, 2006 9:46 pm
What do you mean by that?
Crucible
Real Life Mechanic
Postby RomanV » Sun Jul 16, 2006 10:16 pm
Generally small displacement, high rpm engines dont have much going on down low. (Even more so when modded)
Postby Crucible » Sun Jul 16, 2006 10:41 pm
flygt4 wrote: geez you chose the wrong engine then didnt you :wink:
RomanV wrote:Generally small displacement, high rpm engines dont have much going on down low. (Even more so when modded)
Oh ok Lol, yeah not wrong there :lol:
Is was just curious, think I will just chuck in the Blueys and be done with it, Id be happy with 170 atw but if I get a bit more Id be stoked!!!
Crucible
Real Life Mechanic
Postby crnkin » Sun Jul 16, 2006 10:58 pm
go with the blueysssssssss
crnkin
Postby AE85coupe » Mon Jul 17, 2006 10:17 pm
hey while on the topic of bluetop cams, do you only need the camshafts themselves and thats all, when you want to put the into a red-top, or do you need buckets/shims etc as well?
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby crnkin » Mon Jul 17, 2006 10:55 pm
AE85coupe wrote:hey while on the topic of bluetop cams, do you only need the camshafts themselves and thats all, when you want to put the into a red-top, or do you need buckets/shims etc as well?
Well actually technically you should really re shim the head with new shims..... but hey we drive toyota's here and fix exhaust leaks with soup cans and hose clamps
crnkin
Postby AE85coupe » Mon Jul 17, 2006 10:58 pm
o.k... so for a poor/lazy student/bum type person like myself, do i bother re-shimming it?
Details of car here
AE85coupe
Postby Jebus » Mon Jul 17, 2006 11:37 pm
Nah dude, just chuck them in, if youre realllyy keen check your valve clearances, just read my link above.
Jebus
