slighty_sykotic wrote:Yes.
If you want to know more, then search.
--Sykotic
CircuitLevin wrote:slighty_sykotic wrote:Yes.
--Sykotic
The search algorithm on this forum is terrible, its easier to ask current owners so further specific questions can be asked. But thanks.
BZG|Bling wrote:learn how to search, its FARKIN easy, if you actually follow the instructions,
Bazda wrote:need new plenum.
i would say it will be strong enough for 5psi max or arounds abouts.
Mmm, Boost wrote:Try searching like this:
turbo AND stock AND blacktop....I got 21 matches by doing that.
Amazing how things work when you read the instructions
Al wrote:I believe Nick from NZEFI used his turbo setup from his old setup and put it on a stock silvertop 20v in his aw11, he was racing one day when I was at Ruapuna did something like 12.8 @ 108mph.
CircuitLevin wrote:Al wrote:I believe Nick from NZEFI used his turbo setup from his old setup and put it on a stock silvertop 20v in his aw11, he was racing one day when I was at Ruapuna did something like 12.8 @ 108mph.
Hmmm I forgot about Nicks engine, I should have remembered since he is my flatmate and drove that car a bit before it took up smoking 2 packs a day lol I will have to ask him more when he comes back from holiday...
matt dunn wrote:CircuitLevin wrote:Al wrote:I believe Nick from NZEFI used his turbo setup from his old setup and put it on a stock silvertop 20v in his aw11, he was racing one day when I was at Ruapuna did something like 12.8 @ 108mph.
That was a silvertop bottom end which had the ok rods in it etc.
Will make more power than a tru blacktop would safely.
Al wrote:I believe Nick from NZEFI used his turbo setup from his old motor and put it on a stock silvertop 20v in his aw11, he was racing one day when I was at Ruapuna did something like 12.8 @ 108mph.
matt dunn wrote:This Saturday? Know nothing about it.
I take it is in CHCH?
Matt
CircuitLevin wrote:I did the same search, seems only one of those was about turbo charging a stock blacktop looking at the headings and that was with the factory ECU and no actual people who have done t seemed to pop up with facts about it powerwise.
Lanius wrote:CircuitLevin wrote:I did the same search, seems only one of those was about turbo charging a stock blacktop looking at the headings and that was with the factory ECU and no actual people who have done t seemed to pop up with facts about it powerwise.
If you state that you've already searched and it didn't produce the results you wanted, people are less likely to ask you to use the search function
