3sge reving high
3sge reving high
Postby 2slow4u » Tue Jul 25, 2006 1:07 pm
i just wanted to no if it is normal for my 3sge curren to be at 2000rpm when i start it up its like the auto choke isnt letting go or something .
is this normal if not how do i fix it ?
2slow4u
Postby slighty_sykotic » Tue Jul 25, 2006 1:15 pm
Is this starting from cold?
If so, and it goes down to a more normal idle (around 1000, probably just below) then don't worry about it.
If it won't go down, then it's something you will need to look into.
--Sykotic
slighty_sykotic
Postby solitaire » Tue Jul 25, 2006 2:13 pm
My AE92 Levin is idling at 2400 at cold and 800 at warm 8O
AE92, KZJ120, KDJ120
solitaire
Postby Quint » Tue Jul 25, 2006 2:23 pm
As slighty_sykotic said: If it revs that high when its cold, then its perfectly normal, when it gets to temp it should be idleing >1000, and if so, all good.
Of course, if its revving a little to high when warm, just ajust the idle control on the throttle body (little screw)
Quint
Postby solitaire » Tue Jul 25, 2006 2:29 pm
Yeah i was just trying to say dont panik as it could get higher :D
My idle is turned right down... its a shame i think it could idle lower at warm but it just doesnt want to
solitaire
Postby 2slow4u » Tue Jul 25, 2006 11:34 pm
thanks for that. just thought ild better check before i break something lol
2slow4u
Postby Alex B » Tue Jul 25, 2006 11:38 pm
Your car is EFI so it does not have a choke as such. And that seems about consistant with my 3s-ge. Idle is around the 800rpm mark.
Postby 2slow4u » Tue Jul 25, 2006 11:41 pm
yea it sits at 800rpm when it gets nice and warm but when it gets there a belt starts to squeek/wine a little, which i think may need a little tweak. but its not doing anything wrong at the moment i think
2slow4u
Postby solitaire » Wed Jul 26, 2006 9:31 am
2slow4u wrote:yea it sits at 800rpm when it gets nice and warm but when it gets there a belt starts to squeek/wine a little, which i think may need a little tweak. but its not doing anything wrong at the moment i think
Yeah my 4age does that... you just need to tighten the belt ever-so-slightly... aparently one of the wheels strips its outward facing teeth after a while meaning continuos tightening is required.... happens to me about every 2000ks
solitaire
Postby 2slow4u » Wed Jul 26, 2006 10:06 pm
where do i tighten?
2slow4u
Users browsing this forum: Bing [Bot] and 8 guests
