Valve springs for turbo 4age
Postby no_8wire » Fri Jul 28, 2006 10:01 am
This is directed to those who are running highish boost in their 4agtes...
10+ psi...
What springs are you using? Standard or hardened etc?
no_8wire
Postby IH8TEC » Fri Jul 28, 2006 10:54 am
i'm using std, but being the 4agze motor as the base, i'd think that they are stronger than the n/a ones, if you wanna run silly boost like barry, you'll need heavy duty valve springs
Postby no_8wire » Fri Jul 28, 2006 11:28 am
na Im not a psycho... :lol:
Only 15psi...
no_8wire
Postby IH8TEC » Fri Jul 28, 2006 11:32 am
what head you using? i'd say most 4age heads and std valve springs would be ok for that boost
Postby no_8wire » Fri Jul 28, 2006 11:55 am
bluetop
no_8wire
Postby slighty_sykotic » Fri Jul 28, 2006 12:12 pm
My bluetop head is fine on 14psi.
You should be fine till at least 18-20 i'd say. Probably even higher. I don't think evlgtz was using anything over than std and he was running 18??
--Sykotic
slighty_sykotic
Postby no_8wire » Fri Jul 28, 2006 12:17 pm
Stupid engine reconditioners...trying to tell me I need new springs... :x
no_8wire
Postby Stealer Of Souls » Fri Jul 28, 2006 12:24 pm
Maybe you just need new springs?
Springs sag and can wear over time... Sure they didn't mean, "you just need some new springs cause your old ones are sad.".
'86 AE85.5 Levin
Stealer Of Souls
Postby IH8TEC » Fri Jul 28, 2006 12:28 pm
slighty_sykotic wrote:My bluetop head is fine on 14psi.
--Sykotic
yeah but like his motor, mine, bazda's old one, andy, all are the 4agze motor as a base, allready being supercharged, will have heavier valve springs than the n/a ones expecially for the higher boost, 18+. not saying they wont work, try asking drifter4ag what he used, not sure how much boost he ran on his old setup, 16psi?
Postby slighty_sykotic » Fri Jul 28, 2006 12:37 pm
Hmmm, I can't see any difference in the two springs (got a gze head in bits, as well as a redtop and a bluetop).
Not saying your wrong, but why would toyota do that? Esp when they are only designed for 8ish psi on s/c.
--Sykotic
slighty_sykotic
Postby IH8TEC » Fri Jul 28, 2006 12:42 pm
be a good chance to get the two measured, i should have done it while i had my head apart,
Postby Jebus » Fri Jul 28, 2006 12:53 pm
What cams do you intend to run?
Jebus
Postby Mr Revhead » Fri Jul 28, 2006 12:55 pm
4agze ones are the same as 4age ones
Postby no_8wire » Fri Jul 28, 2006 1:20 pm
stock cams...
no_8wire
Postby 1598cc » Fri Jul 28, 2006 3:02 pm
i used standard springs in my ze. running up to 20psi.
1598cc
Postby no_8wire » Fri Jul 28, 2006 4:23 pm
Stealer Of Souls wrote:Maybe you just need new springs?
Na this is when I went in to get a quote...eg springs, valves everything was still in place and wasnt tested...
no_8wire
Postby Bazda » Fri Jul 28, 2006 6:57 pm
all the 4age heads have the same rate valve springs, they will easily handle up to 20psi 8000rpm.
But to be safe and if ur rebuilding the head and got soem spare cash lying around they arent that expensive, I think around $400 from Performance springs in australia (through Kelford) and that will provide around double the rate from standard.
Postby flygt4 » Fri Jul 28, 2006 7:18 pm
car was running on the dyno this morning. no issues at 21psi with a silvertop head. thats only on dyno tho , havent got the car back yet and had time to test it out. its still to be tidied up with a road tune.
flygt4
Postby CAMB01 » Fri Jul 28, 2006 7:21 pm
Im using Crow Cram springs in my 4AGTE.
The 4age springs i measured have about 40psi seat pressure.
The crow springs have 90psi seat pressure and i paid $100 for them from Kiwicams in palmy.
The cams i have required at least 70psi seat pressure.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Bazda » Fri Jul 28, 2006 7:30 pm
flygt4 wrote:car was running on the dyno this morning. no issues at 21psi with a silvertop head. thats only on dyno tho , havent got the car back yet and had time to test it out. its still to be tidied up with a road tune.
dyno....where are the figures!
