20V valve spring choice
Postby 4000GT » Tue Aug 01, 2006 6:31 pm
Well, just got some Toda cams (272 and 288 with 8.5 and 9.0 lift) and Toda cam gears and TRD head gasket. Now I need some valve springs, Warwick is getting me price and availability on some TRD ones, are there any other options to be found locally? Where have you heard of that stocks them and brands etc?
Supra MKIV Aerotop (UZA80FTE conversion) STATUS: 3 months to go!
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
Free online business and reporting tools visit www.e-solver.com
4000GT
Postby Jebus » Tue Aug 01, 2006 6:36 pm
Jebus
Postby AceSniper » Tue Aug 01, 2006 7:04 pm
There is some TRD ones sitting on Warwick's desk :lol:
AceSniper
Postby 4000GT » Tue Aug 01, 2006 9:06 pm
Jebus wrote:http://forums.toyspeed.org.nz/viewtopic.php?t=48715&start=0
Not looking for springs in a turbo application, its NA.
4000GT
Postby 4000GT » Tue Aug 01, 2006 9:07 pm
AceSniper wrote:There is some TRD ones sitting on Warwick's desk :lol:
lol I may get them yet! Just waiting on Warwick to get back to me!
4000GT
Postby Bazda » Tue Aug 01, 2006 11:13 pm
i got mien from performance springs in australia.
They said they used these on their 20v's with big lift cams and 10k.
Re: 20V valve spring choice
Postby RedMist » Wed Aug 02, 2006 11:02 am
CircuitLevin wrote:Well, just got some Toda cams (272 and 288 with 8.5 and 9.0 lift) and Toda cam gears and TRD head gasket. Now I need some valve springs, Warwick is getting me price and availability on some TRD ones, are there any other options to be found locally? Where have you heard of that stocks them and brands etc?
I gather your intake is the 288 9mm lift cam? If so I would be tempted to go with the spring designed for your cams. IE Toda. Higher than necessary spring tension will wear the valve train, cam, belt faster, will also rob HP. A lower than necessary spring tension.... not good.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Mr Revhead » Wed Aug 02, 2006 11:11 am
currently got the TRD ones away for testing. also getting stock ones tested as a comparison, however they are still on the way from japan.
should have the TRD results this week
Postby Bazda » Wed Aug 02, 2006 11:39 am
Mr Revhead wrote:currently got the TRD ones away for testing. also getting stock ones tested as a comparison, however they are still on the way from japan.
stock was 40/65lbs when I tested them, somewhere in those values anyway, my new ones were 65/95lbs and can be shimmed up to 120lbs.
Postby Mr Revhead » Wed Aug 02, 2006 11:43 am
oh yep.
to be accurate im testing brand new ones of each.
will post all data when i have it.
what exactly do ppl look for when after spring specs? i have to admit to not actaully knowing!
Postby Mr Revhead » Thu Aug 10, 2006 5:12 pm
ok had the TRD ones tested.
and they tested to as they say on the website
dunno what your figures mean barry but the "seat pressure" or whatever you want to call it tested at 15kg which according to my converter is 33lb
as a comparison new ones will be tested as soon as the arrive
Postby Bazda » Thu Aug 10, 2006 7:42 pm
Mr Revhead wrote:ok had the TRD ones tested.
was that the seat pressure, jesus thats crap.......
Postby Mr Revhead » Thu Aug 10, 2006 7:46 pm
we will see how they compare to the stock ones.
bearing in mind the stock ones cna handle quite a bit
Postby RedMist » Thu Aug 10, 2006 8:44 pm
You dont want the seat pressure to increase. Just the spring rate.
RedMist
Postby AceSniper » Thu Aug 10, 2006 8:50 pm
whats the full spec's they gave you?
AceSniper
Postby Mr Revhead » Thu Aug 10, 2006 11:10 pm
as i said above i dont really know how this works
but spring rate i understand!
ill send them back to the test as he just tested they were at the specs shown above.
Postby Bazda » Thu Aug 10, 2006 11:50 pm
see what they are at 8.1mm lift
Postby Diesel PWR » Fri Aug 11, 2006 10:17 am
higher spring pressures wont rob horse power, a spring is an energy storage device, the energy used to compress it is given back when decompressed. I would be looking for a spring with around 60psi seat pressure and checking the installed and compressd height to insure its not going coil bound.
Diesel PWR
Postby Mr Revhead » Fri Aug 11, 2006 11:09 am
ok can some one please clarify the following terms. i think some ppl are using different terms for the same thing.....
now height is pretty simple.
so. what is seat pressure.
by understanding is thats the pressure exerted by the spring with the valve closed?
what other specs are normal?
i gather spring rate?
getting them tested at a certain lift will only apply to one cam.... and as the guy doing this is doing it for free i dont want to piss him off by asking him to do it at 10 different levels
Postby Bazda » Fri Aug 11, 2006 3:22 pm
yes seat pressure is when the valve is closed and 8.1mm is the full lift of a blacktop cam (inlet)
