Jebus wrote:http://forums.toyspeed.org.nz/viewtopic.php?t=48715&start=0
AceSniper wrote:There is some TRD ones sitting on Warwick's desk
CircuitLevin wrote:Well, just got some Toda cams (272 and 288 with 8.5 and 9.0 lift) and Toda cam gears and TRD head gasket. Now I need some valve springs, Warwick is getting me price and availability on some TRD ones, are there any other options to be found locally? Where have you heard of that stocks them and brands etc?
Mr Revhead wrote:currently got the TRD ones away for testing. also getting stock ones tested as a comparison, however they are still on the way from japan.
should have the TRD results this week
Mr Revhead wrote:ok had the TRD ones tested.
and they tested to as they say on the website
dunno what your figures mean barry but the "seat pressure" or whatever you want to call it tested at 15kg which according to my converter is 33lb
as a comparison new ones will be tested as soon as the arrive
RedMist wrote:CircuitLevin wrote:Well, just got some Toda cams (272 and 288 with 8.5 and 9.0 lift) and Toda cam gears and TRD head gasket. Now I need some valve springs, Warwick is getting me price and availability on some TRD ones, are there any other options to be found locally? Where have you heard of that stocks them and brands etc?
I gather your intake is the 288 9mm lift cam? If so I would be tempted to go with the spring designed for your cams. IE Toda. Higher than necessary spring tension will wear the valve train, cam, belt faster, will also rob HP. A lower than necessary spring tension.... not good.
