Doors aren't opening
Postby ollieboy » Sat Aug 05, 2006 2:22 pm
Hey,
I just bought a 1983 Corona and the two back doors won't open or unlock. Its a real mongrel, I can't work out why they won't open. Anyone had experience with this before? :?
Is it possible to open a door without the handle?
Ollie
ollieboy
Postby RS13 » Sat Aug 05, 2006 2:35 pm
Take the interior panel off, (it'll be hard with the door closed, but its' doable) work out which rod connects the handle to the locking mechanism, and pull it.
It seems odd that both doors are knackered.. maybe child locks are broken?
Either way, once you get them open, you'll see how the mechanisms work, they're quite straightforward.
RS13
Postby mikeygtt » Sat Aug 05, 2006 2:36 pm
so they wont open from inside or out :?: child locks :?:
uhmmm yup
mikeygtt
Postby ollieboy » Sat Aug 05, 2006 2:43 pm
Won't open from either way. I was hoping I wouldn't have to take the panels off but oh well. Cheers
ollieboy
Postby KinLoud » Sat Aug 05, 2006 4:51 pm
I've had a similar problem with my Carina
In my case the outside door handle wasn't springing back down far eough an so the lock/unlock levers weren't able to move.
Get some crc - spray it up under the outside handle. Work the handle up and down with what movement you do have. I used a tiny screwdrivier to help lever the handle all the way down once it was sort of free.
Once it is all the way down the locks should work.
Open the door - take off the door card and oil everything but most attention to the door handle pivot points.
Good luck
Ken
Ham
021 408 863
Postby ollieboy » Sat Aug 05, 2006 5:07 pm
KinLoud wrote:I've had a similar problem with my Carina
Good luck
Ken
Ham
021 408 863
Thats the exact same situation I have, must be a problem with that type of vehicle.
Cheers man :)
ollieboy
Postby ollieboy » Sat Aug 05, 2006 5:15 pm
You are a legend. I did exactly as you said and it worked.
This should be faq'd or KinLoud given a medal or something. :)
ollieboy
Postby KinLoud » Sat Aug 05, 2006 5:53 pm
Random medal for me ;)
I'm glad I could help!
Good old school toyotas!
Ken
Ham
021 408 863
