I just bought a 1983 Corona and the two back doors won't open or unlock. Its a real mongrel, I can't work out why they won't open. Anyone had experience with this before?
Is it possible to open a door without the handle?
Ollie
KinLoud wrote:I've had a similar problem with my Carina
In my case the outside door handle wasn't springing back down far eough an so the lock/unlock levers weren't able to move.
Get some crc - spray it up under the outside handle. Work the handle up and down with what movement you do have. I used a tiny screwdrivier to help lever the handle all the way down once it was sort of free.
Once it is all the way down the locks should work.
Open the door - take off the door card and oil everything but most attention to the door handle pivot points.
Good luck
Ken
Ham
021 408 863
