4AGE questions..
4AGE questions..
Postby RS13 » Mon Aug 07, 2006 12:35 am
Further to my other post; I have tried searching for the answers, but can't find anything definite!
Silvertop extractors. I have been offered a set, with most of an AE101 exhaust, for $80. Is that good? And are these a bolt on to my smallport, or will I have to redo the flange, or just slot holes.. ?
TRD headgasket. I have also been offered one of these by the same person, I didn't really want to open my motor up until I had to, but would the performance gain be worth it? I'm not sure what thickness it is, I also don't want to put it in and find the car is a thirsty, detonating bag of sh*t to drive! Opinions? Worth it with factory cams, or is that really dependant on what thickness it is?
Is the air temp sensor currently attached to the airbox totally necessary? Apparently I need to incorporate it into the intake, but I can't see an easy way to do it.
And TEMS! I appear to have 2 suspension options, "soggy" and "not so soggy". I'm just looking to rip them out, and replace them with KYBs or the like, will this affect anything (throwing codes?) electrical?
Any advice would be much appreciated.
RS13
Postby HELBND » Mon Aug 07, 2006 11:02 am
if youre going to get 20v extractors, dont bother with silvertop ones, theyre puny compared to blacktop. ideally, you also want the 2-1 section. $80 is a bit dear, expect to pay around $50 for extractors AND 2-1 section (blacktop). and no, they wont just bolt up, they need to be modified slightly
HELBND
Re: 4AGE questions..
Postby Stealer Of Souls » Mon Aug 07, 2006 2:27 pm
RS13 wrote:Silvertop extractors. I have been offered a set, with most of an AE101 exhaust, for $80. Is that good? And are these a bolt on to my smallport, or will I have to redo the flange, or just slot holes.. ?
IMO Probably not too bad a price for a whole exhaust... But considering all you want is the extractors and 2 into 1 section.
I get the impression that the silvertop extractors are better than 16V versions, but need to slot a couple of holes to get them on.
RS13 wrote:TRD headgasket. I have also been offered one of these by the same person, I didn't really want to open my motor up until I had to, but would the performance gain be worth it? I'm not sure what thickness it is, I also don't want to put it in and find the car is a thirsty, detonating bag of sh*t to drive! Opinions? Worth it with factory cams, or is that really dependant on what thickness it is?
Not too sure about this... But it may not do squat. If it's the same thickness as your factory one it will be an expensive waste of time.
RS13 wrote:And TEMS! I appear to have 2 suspension options, "soggy" and "not so soggy". I'm just looking to rip them out, and replace them with KYBs or the like, will this affect anything (throwing codes?) electrical?
Try getting brand new TEMS from Revhead. If all you've got is soggy and soggier, then they're probably really stuffed. Last TEMs I drove on were suitably firm for street use on the hard setting.
'86 AE85.5 Levin
Stealer Of Souls
Postby escortman » Mon Aug 07, 2006 5:20 pm
not to sure about the extractors but blacktops are bigger
its not recommened to use the trd gaskit here because of the crap fuel speak to revhead anyway
you can get new shcosk form toyota and still have the tems or go to some adjustable kybs, i have coilovers now so cant do anything bad to the electronics
4x4 toyota blizzard offroader
escortman
Postby Mr Revhead » Mon Aug 07, 2006 5:28 pm
i dont recomend the TRD gasket for the blacktop for a road car.
the others are ok.
Postby RS13 » Mon Aug 07, 2006 11:27 pm
Okay, cheers. I'll get the extractors, and see what I can do. I've got a pod filter and some aluminium piping, I'm going to try and incorporate the ATS, but we'll see. I'm not going to bother with the head gasket, with decent cams to work with it, it would probably be more cost-effective to just drop in a silver/blacktop!
Cheers for the advice guys. I'm still wanting further advice/info on setting up the intake.
RS13
Postby Jebus » Mon Aug 07, 2006 11:32 pm
Get a 45 degree silicone joiner and a straight piece of aluminium piping, put the silicone from the TB to the pipe, stick the sensor into the silicone bend, then stick ya pod filter on the pipe. Then build a heat shield around it, cos it will only suck in hot air.
Jebus
92 GT Levin workshop manual???
Postby amadaun » Tue Aug 08, 2006 4:22 pm
Hi there.
I'm a newbie, with what is probably a stupid question, but I gotta ask it. :oops:
We recently acquired a 92 GT Levin, [20 valve 4 age- as I'm sure you all know] for my son.
We'd like to be able to have a twiddle with the motor, but have been unable to find any workshop manuals to help.
Techbooks in Newmarket said the only manuals availabe are for standard Corollas with the 4 age motor. Does anyone have any suggestions where I might find this kind of info? thanks.
~~~AE101 GT Apex Levin~~~
amadaun
Re: 92 GT Levin workshop manual???
Postby AE85coupe » Wed Aug 09, 2006 10:29 pm
amadaun wrote:Hi there.
the standard corolla manuals will be fine, providing the are for late model corollas with 20v 4ages in them (levin = corolla levin)
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby Bling » Wed Aug 09, 2006 11:17 pm
amadaun wrote:Hi there..... etc etc
what exactly do you plan on fiddling with?
got anything in mind, as i'm sure it would have been done by someone on this forum before, just a case of using search and you might get more ideas at the same time..
my 2c
Postby amadaun » Thu Aug 10, 2006 12:03 pm
Hi guys, thanks for your replies.
The first bit of fiddling we'd like to do, is to get it running sweet to start with!!
Sometimes when its warm the idle slows right down, and also its a bit surgey [is that a word?] in second.
So, we're rank beginners...... but you gotta start somewhere, right?
Re ~the Corolla manuals, I thought the GT Levin might have a different set up to a standard Corolla?
thanks again!!
Image[/img]
amadaun
Postby AE85coupe » Thu Aug 10, 2006 3:05 pm
amadaun wrote:Hi guys, thanks for your replies.
thanks again!!
Image[/img]
engine is the same dude, providing its the 20v 4age
Details of car here
AE85coupe
Postby matt dunn » Thu Aug 10, 2006 9:05 pm
amadaun wrote:Sometimes when its warm the idle slows right down, and also its a bit surgey [is that a word?] in second.
start here for that
viewtopic.php?t=46052
Postby amadaun » Fri Aug 11, 2006 3:38 pm
Yeah its a 20v, and hey..... its dudess!! :oops:
Nice Trueno. Super low prof tyres..... look hot. :D
amadaun
Postby AE85coupe » Fri Aug 11, 2006 4:00 pm
amadaun wrote:engine is the same dude, providing its the 20v 4age
cheers dudette
Details of car here
AE85coupe
Postby Mr Revhead » Fri Aug 11, 2006 4:09 pm
dudess? thats my que 8)
what fuel are you running it on?
also test the coil lead
Postby amadaun » Fri Aug 11, 2006 4:30 pm
Umm.......... just standard 91.
amadaun
Postby Mr Revhead » Fri Aug 11, 2006 4:34 pm
theres your problem.
you need at LEAST 95 and even then you need to retard the timing to 8 deg
try it on a tank of 98
Postby amadaun » Fri Aug 11, 2006 4:42 pm
Thanks for that, I'll see if I notice any difference when I fill up next.
If only the handbook wasn't written in Japanese! :?
amadaun
Postby Mr Revhead » Fri Aug 11, 2006 4:44 pm
you will see a difference!!
i can do you an english manual for about $40
