More Grunt From 1KZ-TE
Postby Muzzie » Sun Sep 10, 2006 8:15 pm
96 Hiace coach, 1KZ-TE (Turbo 3.0L Diesel)
Wanting a bit more exhaust sound, and a bit more get up and go.
Not after a quick fix - will be permanent & must be reliable. Tows a car trailer too, so more torque wouldn't go a miss.
And what sorta boost can be safely run through one of these. I'm not talking running it up to 20 PSI or anything stupid, but if I can safely run a couple more PSI through it then why not.
Not unlimited budget obviously, but not chicken feed budget either :)
Muzzie
Regular Poster
Postby Mr Revhead » Sun Sep 10, 2006 8:23 pm
swap it for a 1kdte :D
Postby Muzzie » Sun Sep 10, 2006 8:25 pm
Mr Revhead wrote:swap it for a 1kdte :D
Muzzie
Regular Poster
Postby Pelo » Sun Sep 10, 2006 8:30 pm
1KD-FTV, new hilux 3 litre common rail diesel engine. Bloody grunters!
The new hiaces have a 2KDFTV, 2.5 litre version.
Pelo
Postby Mr Revhead » Sun Sep 10, 2006 8:32 pm
oh yeah 1kdftv :lol:
Postby tatsumaki » Sun Sep 10, 2006 8:37 pm
Not sure if V8s are your thing but Toyota did actually do Hiaces in V8 form as a JDM special vehicle (eg. Ambulances). Used the 1UZ-FE naturally.
PB.
tatsumaki
Postby Mr Revhead » Sun Sep 10, 2006 8:40 pm
those were converted ex factory :wink:
but still, can be done!
Postby tatsumaki » Sun Sep 10, 2006 8:45 pm
Mr Revhead wrote:those were converted ex factory :wink:
Yeah, that's the one mate. UZH122V chassis they called it or something.
It doesn't feature on the EPCs though.
Mal's got a spec sheet on it from Michelle B a while back.
Interesting read! :)
PB.
tatsumaki
Postby Muzzie » Sun Sep 10, 2006 9:40 pm
I'm listening............
Although, I'm pretty sure my original thoughts still involved keeping the original motor :P
Muzzie
Regular Poster
Postby Lloyd » Sun Sep 10, 2006 9:43 pm
Those there were 1UZ vans from factory?
The 1KZ-TEs dont go too bad standard, bit more boost would probably make it go a bit better but end of the day... look what you're playing with. Put a 1HD in it :D
Postby Muzzie » Sun Sep 10, 2006 9:45 pm
*decides to rephrase*
Long term project might involve a 1UZFE yes.
For now, I want more grunt from what I have!
Muzzie
Regular Poster
Postby sergei » Sun Sep 10, 2006 11:19 pm
maybe pipe in some intercooler? crank up the boost (i think they run 13psi from factory)... adjust fuel pump...
Postby NFORCA » Mon Sep 11, 2006 11:38 am
Aparently putting a larger exhaust on helps, as does adding an intercooler if it doesnt have one already.
NFORCA
Postby eritate » Mon Sep 11, 2006 12:07 pm
A 1k is fitted with a ct20 ?
I am a timewaster. Ignore anything I say
eritate
Postby Mr Revhead » Mon Sep 11, 2006 12:13 pm
NO
it has a 17201-67010
the "ct20" was on the 3t or somthing
please dont add more fake turbo names :cry:
Postby sergei » Mon Sep 11, 2006 12:16 pm
off topic but what is the part number of steel "CT20b", I already threw away the box from it...
Postby Mr Revhead » Mon Sep 11, 2006 12:35 pm
17201-74080
Postby sergei » Mon Sep 11, 2006 1:31 pm
so basically 17201 partof the number is for turbo, so shell we call it 74080 turbo instead of CT20b becuase it is not CT20b?
Postby Mr Revhead » Mon Sep 11, 2006 1:40 pm
sounds good to me 8)
Postby CaM » Mon Sep 11, 2006 1:44 pm
'tis generic name etc.
CaM
