another 4k question
another 4k question
Postby Mike- » Thu Sep 14, 2006 9:37 pm
well i discovered id cracked the head on my engine so that has come off and i got a new one which has been acid dipped, its not cracked or warped either :) but, the valves are sitting there loose, my question is how do i get the valve into those little half round clips, and is there anything i should do to clean up the valves they looks pretty dirty,
any help appreciated
Mike-
Postby Dell'Orto » Fri Sep 15, 2006 11:57 am
With a valve spring compressor ;) As for cleaning them, nah not too much of a biggy. Parts washer might bring them up.
Postby Mike- » Fri Sep 15, 2006 7:10 pm
ahh k, neway to do it without the right tools?
Mike-
Postby Snoozin » Fri Sep 15, 2006 7:16 pm
Clean all the carbon deposits etc off the valves with a wire wheel on a bench grinder
Snoozin
Postby Loudtoy » Sun Sep 17, 2006 8:45 am
Mike- wrote:ahh k, neway to do it without the right tools?
And you'd be hard pressed to get it all back together without the right tools
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby Mike- » Sun Sep 17, 2006 1:22 pm
yeh hard enuf doing 1 let alone 8, im off to buy one , neone got a second hand one the dont want anymore>??
Mike-
Postby Dell'Orto » Sun Sep 17, 2006 8:54 pm
They're pretty cheap, I think the Powerbuilt one retails at like $35 or so
Postby AE91Sprinter » Sun Sep 17, 2006 11:45 pm
f clamp + a bit of alu/ms tube with a slot cut in it. Works, but its fiddly as hell.
AE91Sprinter
Postby Mike- » Mon Sep 18, 2006 10:02 am
yeh i gave up on the makeshift one and bought one from repco, for $40,
now that thats done, wat is the setting for the tapits?
Mike-
Postby dickhead » Thu Nov 09, 2006 4:06 pm
you can just but a big spanner over the top of the spring washer and lean on it. you need someone to help tho by putting the little fiddley bits in
dickhead
