id needed
id needed
Postby bluemaumau » Sat Jan 06, 2007 1:31 pm
any one know what this is
ae92 afm 4agze
on the inlet/ flywheel side,
whatever it is if its not pluged into the loom, would it cause the engine check light to be on?
Postby Adydas » Sat Jan 06, 2007 2:20 pm
Looks like your knock sensor to me and yes not been plugged in could cause the light to be on.
Adydas
Postby themaleman » Sat Jan 06, 2007 2:21 pm
yep that little bastard is a temp sensor (block i presume) the ae92 1's are made out of a shit material, i broke 2 of them trying 2 get them in and hooked up, in the end i used 1 off an ae101 (made from something a little stronger than the ae92 1) when mine wesnt plaged in the car ran like shit and yes the engine check light kept cumming on. hope this helps man
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Adydas » Sat Jan 06, 2007 2:46 pm
Well there ya go..
Adydas
Postby Caveman » Sat Jan 06, 2007 6:13 pm
w00t? that looks exactly like a knock sensor... under intake manifold around number 2 cylinder?
temp sensors go near water pump and sensor housing coming off number 4 out the end of the head.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby bluemaumau » Sat Jan 06, 2007 6:45 pm
dylan its the cyclinder closet to the flywheel, so that makes it 1 or 4. :oops:
Postby Caveman » Sat Jan 06, 2007 6:55 pm
bluemaumau wrote:dylan its the cyclinder closet to the flywheel, so that makes it 1 or 4. :oops:
closet to flywheel is 4 :wink:
on smallport the knock sensor is between 2 and 3. Maybe they changed the location on your model 4a block
AW11 Track Toy
Caveman
Postby bluemaumau » Sat Jan 06, 2007 6:56 pm
sweet is it a green plug on the loom?
Postby Caveman » Sat Jan 06, 2007 7:03 pm
disreguard what I said :oops:
Just read you have AFM model, they dont run knock sensors but im not sure what the sensor is. They are a green plug, I just rewired one of these last week :oops:
AW11 Track Toy
Caveman
Postby bluemaumau » Sat Jan 06, 2007 7:05 pm
hmmm bugger, ive got cam troubles now neway
Postby Xyrath 86 » Sat Jan 06, 2007 8:01 pm
It looks like a 7rib (late model block, unless early gze's are 7rib too?) anyway so it could be a knock sensor that was left in the block but not used?
Xyrath 86
Postby l1ttle_d3vil » Sat Jan 06, 2007 8:29 pm
ive got this same plug on my aw11 4agze too, same place ect. its an aw11 bigport 4agze, dizzy / afm.
Postby bluemaumau » Sat Jan 06, 2007 8:30 pm
mines afm from a ae92
Postby IH8TEC » Sat Jan 06, 2007 8:52 pm
IT IS YOUR KNOCK SENSOR. nuff said, no more temp sensor crap.
and when you run the loom, look for the loose connector thats down those ways,
edit, and it's between 3 and 4 on that block
Postby bluemaumau » Sat Jan 06, 2007 8:53 pm
loose connector? wtf
Postby IH8TEC » Sat Jan 06, 2007 8:57 pm
when engine is in the car, there will be a connector that you haven't plugged in. it will go onto the knock sensor. :D you running the gze engine loom?
Postby bluemaumau » Sat Jan 06, 2007 8:58 pm
oh yea i figured that man, i was tryna find were the plug pluged into for ages and gave up and now the engines out again i found it so i was just wondering what it was.
cheers mate
Postby Caveman » Sat Jan 06, 2007 10:15 pm
Hmmm yea it looked exactly like a knock sensor, same plug and everything.
I didnt think these cars ran them...
On later model ae92 the sensor goes between 2 and 3 on the intake side. Ill check the early ae92 gze motor tmr.
AW11 Track Toy
Caveman
Postby Mr Revhead » Sat Jan 06, 2007 10:19 pm
yes thats a knock sensor
yes afm 4agzes have them
yes having it unplugged will cause the check light to be on (code 52 iirc)
Postby IH8TEC » Sun Jan 07, 2007 1:38 am
1998 wrote:Ill check the early ae92 gze motor tmr.
dont worry dylan, jsut trust me on this one
