Gen 1 SW20 /Gen2 3sgte Engine Management
Postby solitaire » Sun Jan 14, 2007 5:53 pm
What do you guys use for engine management?
Apexi dont make a plug n go solution, would prefer to stay away from piggy back... was thinking that link is the best choice...
Generally just interested if anyone has an opinion on this topic...
AE92, KZJ120, KDJ120
solitaire
Postby Boosted_162 » Sun Jan 14, 2007 5:56 pm
I think link is the only plug-in available? Ill be going for a G3 when i get round to an ecu, so much easier for the wiring noobs.
Cliff uses a Motec, will be nice to see his results.
Postby strx7 » Sun Jan 14, 2007 7:05 pm
personally I prefer Haltech, a New E6X will cost around $1500-1600.
I have used Haltech for 6 years, know them inside out, so dont need to learn something new, so every car i build i use one on.
Postby solitaire » Sun Jan 14, 2007 7:05 pm
Boosted_162 wrote:I think link is the only plug-in available? Ill be going for a G3 when i get round to an ecu, so much easier for the wiring noobs.
Exactly what i was after thanks man :D so a link g3 is essentially a plug 'n' play? (with tuning etc as well of course) No arseing about with the wiring?
solitaire
Postby Adydas » Sun Jan 14, 2007 7:09 pm
viewtopic.php?t=53814
LEM G3 + adaptaLink $1590 inc
Plugin replacement for Mazda (MX5/GTX/GTR), Nissan (R32/R33/S13/S14/S15/N14/GTiR), Subaru (WRX V1-6/RS), Toyota (SW20/ST185/ST205).
Mate runs a Motec in his MR2 and highly reccomended it to me and his tuner, his cars mad modified but he says it drives like factory but with rad power.
Adydas
Postby fivebob » Sun Jan 14, 2007 7:10 pm
Any ECU can be made plug and play for the Gen II 3S-GTE using this adapter http://www.mrcontrols.com/products/pnpboard.htm :wink:
Postby Akane » Sun Jan 14, 2007 7:15 pm
Buy my PowerFC imo.
Postby solitaire » Sun Jan 14, 2007 7:31 pm
Akane wrote:Buy my PowerFC imo.
:lol:
rent to own? :(
Id do the group buy on the LEM if my money wasnt tied up in the bloody wedding...
besides... the power fc's dont work on the gen2s out of the box... at least thats what everyone (including apexi) told me
solitaire
Postby Adydas » Sun Jan 14, 2007 7:38 pm
you can get a version that will work out of the box its been haxord by another company to work with the AFM as apposed to the apexi programmed MAP.
You need to find your self an AP engeneering Power FC.
you SHOULD find this to be the part number to :P
4E14T04Z
Adydas
Postby solitaire » Sun Jan 14, 2007 8:15 pm
Adydas wrote:you can get a version that will work out of the box its been haxord by another company to work with the AFM as apposed to the apexi programmed MAP.
4E14T04Z
oh right, have you got one?
The boys on mr2oc said it wasnt good... and that most us tuners wouldnt touch them... but that is yanks though....
solitaire
Postby mister2 » Sun Jan 14, 2007 8:43 pm
Depends on your requirements - Link LEM G3 + adaptor for $1590 is pretty hard to beat value for money. If you want to run over 22psi boost you'll need the MAP sensor upgrade ($135 for 55psi). PowerFC are good but a little dearer.
MoTeC are great too if you have the datalogging requirements and the bank balance.
Nick
www.nzefi.com
4WD Dynapack Dynamometer.
Link, MoTeC, Greddy, Power FC sales support and tuning.
Weapon of Choice: 1992 NSR250 SE
On hiatus, current location: Cambridge, UK
mister2
Postby solitaire » Sun Jan 14, 2007 8:51 pm
mister2 wrote:Depends on your requirements - Link LEM G3 + adaptor for $1590 is pretty hard to beat value for money. If you want to run over 22psi boost you'll need the MAP sensor upgrade ($135 for 55psi). PowerFC are good but a little dearer.
Nick
Thanks nick... perhaps i should tell you what i want to achieve eh? :D
I would like to join the 200kw club, which i would like to do with the Steel Wheel CT20b & Aussie downpipe that i got from Al (obviously with a lot of other bits)
As my Gen 2 3sgte has slightly higher compression than the later gens im hoping to be able to make that with less than 20psi.
It would be nice if it was able to be installed into other vehicles in the future, should i ever decide to sell the mr2...
solitaire
Postby mister2 » Sun Jan 14, 2007 9:11 pm
Realistically either an LEM G3 or Power FC will get you to the 200kw club with factory driveability, ECU's don't make power (!), tuning does. You'll get launch control (or antilag) with the LEM which impresses the ladies :lol:
What info are you after?
Nick
www.nzefi.com
mister2
Postby solitaire » Sun Jan 14, 2007 9:47 pm
Thanks Man, Yeah i realise that an ecu doesnt actually give power per say.... but i realised it was rather flange-like to say "whats best for me?" without actually telling you my intended application :lol:
Anti lag is something im very interested in from a performance point of view, I'm getting married in a month so i dont need to try anymore :lol:
The only other application i would realistaly ever want to use it for would be an A, J or U series engine.
So the Lem sounds good for me...
Are there any advantages the more pricer solutions have over a lem?
solitaire
Postby mister2 » Sun Jan 14, 2007 10:00 pm
Umm... about the only major one I can think of is knock sensing, both the LinkPlus and Power FC have this but the LEM doesn't. That being said, it isn't that critical unless you go running the car on lower octane than it is tuned for. With the Power FC you'll have to retain the AFM too, unless you pay through the nose for an APS one.
LEM/LinkPlus will also get you boost control with a additional boost control solenoid, allows you to run a "boost knob" to adjust boost in cabin.
About the only other one is support, Link is pretty good for that if anything goes wrong, whereas it is a little trickier with Apexi.
Anyway we can supply LEM + adaptor for $1590 and with the current group buy that includes the required inlet air temp sensor ($120).
Hope this helps.
Nick
www.nzefi.com
mister2
Postby solitaire » Mon Jan 15, 2007 7:43 am
Very, Very Helpfull... now just gotta find the cash :(
solitaire
Postby Akane » Mon Jan 15, 2007 8:57 am
My AP Engineering PowerFC was pay & plug & play on my Gen 2 3S-GTE MR2. I paid extra for this version which is repinned and has software loaded for the Gen 2's MAP sensor.
Postby solitaire » Mon Jan 15, 2007 9:04 am
Akane wrote:My AP Engineering PowerFC was pay & plug & play on my Gen 2 3S-GTE MR2. I paid extra for this version which is repinned and has software loaded for the Gen 2's MAP sensor.
Ok, The only reason i wasnt keen is that mr2oc.com forums say that the ap engineering version is pants... you reckon its ok?
solitaire
Postby Akane » Mon Jan 15, 2007 11:52 am
Even after I tried explaining to mr2oc about how AP Engineering adapted the PFC to the point where it's plug and play on Gen 2, they are still confused.
Well, it got me to the 200rwkw club, plug and play and I installed the optional air temp sensor, and it controls my 550cc injectors (which I even adjusted the lag time myself, it's that simple). so I'd say yeah, it did OK to me.
Postby solitaire » Mon Jan 15, 2007 1:41 pm
Akane: Ok... So how much are you after and why are you selling it?
(i dont have the cash now but i would like to have an idea of cost).
Mister 2: Is there any other way of detecting knock if/when i go lem? A simple light on the dash or a counter would do fine... just so i can keep an eye on it...
solitaire
