4agte + tvis on a link ecu?
Postby l1ttle_d3vil » Sun Jan 14, 2007 10:32 pm
i've heard mixed opinions about running TVIS on a turbo 4age, mostly because of the fact that the butterflies could get sucked into the engine or something...is that really likely to happen??
also, is it possible to run the TVIS butterflies with a link computer (lem g3) or is it more trouble than its worth?
cheers.
Postby sergei » Sun Jan 14, 2007 10:37 pm
For your information the 3SGTE (gen1 and gen2) had TVIS.
Postby mister2 » Sun Jan 14, 2007 10:48 pm
Yeah it works well, you get good low end with the butterflies closed then open them on boost.
No reason not to run them - at least while you have a stock intake manifold anyway.
Nick
www.nzefi.com
4WD Dynapack Dynamometer.
Link, MoTeC, Greddy, Power FC sales support and tuning.
Weapon of Choice: 1992 NSR250 SE
On hiatus, current location: Cambridge, UK
mister2
Postby l1ttle_d3vil » Sun Jan 14, 2007 11:03 pm
mister2 wrote:No reason not to run them - at least while you have a stock intake manifold anyway.
will be running stock ae86 inlet manifold so no problems there.
so can it be wired up so the butterflies are controlled by the link?
Postby sergei » Sun Jan 14, 2007 11:12 pm
You should be able to use RPM switch to activate TVIS solenoid at ~4500rpm...
Postby AceSniper » Sun Jan 14, 2007 11:12 pm
yes... using a aux output... rpm selected on/off
AceSniper
Postby flygt4 » Mon Jan 15, 2007 6:53 am
i think slideways tried with and without and ended up keeping them
flygt4
Postby ~SlideWays~ » Mon Jan 15, 2007 9:03 am
flygt4 wrote:i think slideways tried with and without and ended up keeping them
Yep, made a huge improvement to bottom end/off boost torque and response. I'm using a link plus G1 which has more aux outputs than the older v4/5's I think, but the G3 is probably better than the Link Plus G1 anyway (I haven't looked at the specs actually).
So short answer is yes it is a very good idea to run it and the G3 should have a spare rev switch to control the TVIS.
~SlideWays~
Postby ~SlideWays~ » Mon Jan 15, 2007 9:05 am
I had Speedtech tune it and what Andre did was one run with TVIS closed and one with it open and compared the graphs to find the point to switch.
From memory it was 4200rpm, but that would depend on your turbo and compression etc.
~SlideWays~
Postby IH8TEC » Mon Jan 15, 2007 10:02 am
hmmm, cause i'll probably be putting tvis on my car when i go the link, lets hope the lem4 can control this.
in the manual of the lem4, it has under the features
idle speed control for two wire solenoids OR electronic boost control OR one high power drive switchable at a preset RPM or engine load
does the highlighted bit indicate that it would be able to control the tvis solenoid at the load?
Postby sergei » Mon Jan 15, 2007 10:33 am
You can get a kit from jaycar that will do rpm switching,
here it is:
frequency switch
Postby ~SlideWays~ » Mon Jan 15, 2007 10:45 am
IH8TEC wrote:hmmm, cause i'll probably be putting tvis on my car when i go the link, lets hope the lem4 can control this.
I think the lem4 might not have enough outputs to be able to control cold start idle and rev switch and boost switch (unless you're using something else?)
Maybe give the supplier a call and see if there are any options to upgrade the lem4?
~SlideWays~
Postby IH8TEC » Mon Jan 15, 2007 10:46 am
thats what the OR is for, meaning you can have only one of those options for that wire/s. plus i don wanna upgrade it as i got it at a good price. lol. not yet anyway
Postby ~SlideWays~ » Mon Jan 15, 2007 10:49 am
Shit you're like a hawk watching this thread :lol: 1 min response!
Cheapest option then would be the jaycar rev switch. Thats what I was going to do until I decided to just splash out on a LinkPlus.
~SlideWays~
Postby IH8TEC » Mon Jan 15, 2007 10:50 am
true, this is less than a minute, i'm at home sick man :lol: might be the go aye, little way in the future anyway, time to think
Postby ~SlideWays~ » Mon Jan 15, 2007 10:56 am
heh, Im at work :lol: not quite as fast though.
~SlideWays~
Postby IH8TEC » Mon Jan 15, 2007 11:01 am
i'll talk to the guy tuning it, see what he says, the v5 ones can i know that, but we'll see. i need something down low haha
Postby Stealer Of Souls » Mon Jan 15, 2007 11:28 am
A little OT...
In regards to normal TVIS operation. What's the order of things? When are the butterflies open and when are they closed?
'86 AE85.5 Levin
Stealer Of Souls
Postby ~SlideWays~ » Mon Jan 15, 2007 11:57 am
Stealer Of Souls wrote:A little OT...
Closed till 4500ish.
~SlideWays~
Postby Stealer Of Souls » Mon Jan 15, 2007 1:44 pm
Okay...
Interesting...
I'm not 100% sure I'm reading my manuals correct... But I think they're suggesting that the butterflys are closed after the switch point...
And this is the same in my Haynes manual for the bigport redtop, and for my Toyota manual for the bluetop...
I will try to post up the actual wording from the book tonight...
'86 AE85.5 Levin
Stealer Of Souls
