mister2 wrote:No reason not to run them - at least while you have a stock intake manifold anyway.
flygt4 wrote:i think slideways tried with and without and ended up keeping them
IH8TEC wrote:hmmm, cause i'll probably be putting tvis on my car when i go the link, lets hope the lem4 can control this.
in the manual of the lem4, it has under the features
idle speed control for two wire solenoids OR electronic boost control OR one high power drive switchable at a preset RPM or engine load
does the highlighted bit indicate that it would be able to control the tvis solenoid at the load?
~SlideWays~ wrote:IH8TEC wrote:hmmm, cause i'll probably be putting tvis on my car when i go the link, lets hope the lem4 can control this.
I think the lem4 might not have enough outputs to be able to control cold start idle and rev switch and boost switch (unless you're using something else?)
Maybe give the supplier a call and see if there are any options to upgrade the lem4?
IH8TEC wrote:~SlideWays~ wrote:IH8TEC wrote:hmmm, cause i'll probably be putting tvis on my car when i go the link, lets hope the lem4 can control this.
thats what the OR is for, meaning you can have only one of those options for that wire/s. plus i don wanna upgrade it as i got it at a good price. lol. not yet anyway
Stealer Of Souls wrote:A little OT...
In regards to normal TVIS operation. What's the order of things? When are the butterflies open and when are they closed?
