tex wrote:From some place.....
AW11 - use an E51, with the linkages facing forwards
AE92/92 - use an E58 and E52. Quite rare to get an LSD though, if you do, it will 90% likely be a MAP sensor version.
AE101 - use E58, and LSDs are far more common.
E58-474 -> open centre
E58-11C -> LSD
E58-XX* -> where XX are two numbers, if * is odd, you have LSD.
E58 LSD and NON-LSD CV shafts are non-interchangeable.
E51 LSD and NON-LSD CV shafts ARE interchangable.
