What CV's
What CV's
Postby TRD_ZERO » Sun Jan 21, 2007 8:02 pm
OK i think i found what i needed..........but now more questions to follow...........will i need Mr2 inner cvs to work the viscous lsd? Or will my current e51 cvs work? And lastly is there such a thing as LSd and Non lsd shafts if so what is the difference? more splines? longer cv's or??
TRD_ZERO
Postby TRD_ZERO » Mon Jan 22, 2007 6:03 pm
No one knows :evil: ? all i can find is this
E51/E153-732 2 spider open
E51/E153-733 2 spider lsd
E51/E153-734 4 spider open
E51/E153-735 4 spider lsd
TRD_ZERO
Postby Boosted_162 » Mon Jan 22, 2007 10:17 pm
viewtopic.php?t=32117
That should answer your question.
Postby TRD_ZERO » Tue Jan 23, 2007 7:07 pm
TRD_ZERO
Postby bluemaumau » Tue Jan 23, 2007 8:20 pm
lsd shafts have longer splines
Postby tex » Tue Jan 23, 2007 8:41 pm
From some place.....
AW11 - use an E51, with the linkages facing forwards
AE92/92 - use an E58 and E52. Quite rare to get an LSD though, if you do, it will 90% likely be a MAP sensor version.
AE101 - use E58, and LSDs are far more common.
E58-474 -> open centre
E58-11C -> LSD
E58-XX* -> where XX are two numbers, if * is odd, you have LSD.
E58 LSD and NON-LSD CV shafts are non-interchangeable.
E51 LSD and NON-LSD CV shafts ARE interchangable.
tex
Postby TRD_ZERO » Wed Jan 24, 2007 7:05 am
tex wrote:From some place.....
E58-11C -> LSD
Oh ok so the e51 lsd and non lsd shafts are the same( i thought so as if mine went in any further they would hit). So last question will my e51 shafts fit the e153 viscous lsd when in a e51 g/box or will i need Mr2 inner cv's for that to work?
TRD_ZERO
Postby tex » Wed Jan 24, 2007 11:51 pm
90% sure that the E153 sw20 VLSD and non LSD shafts are the same. In saying that, having had a quick compare of the e51 AW11 manual and E153 SW20 shafts they seem the same. Hence they should work. As for putting a VLSD into a E51 or other E series...pass. There was a mention of housing size differences because of how the VLSD works. Helical and plate are straight swap in though. Go figure.
TEX
tex
Postby TRD_ZERO » Thu Jan 25, 2007 2:54 pm
HHMmm so it is likely that my e51 shafts will work work with this lsd now i have to find out if the lsd will fit into this box.
TRD_ZERO
Users browsing this forum: Google [Bot] and 2 guests
